Author Topic: List of all standard info  (Read 6842 times)
GerryH
« on: January 15, 2006, 12:07:25 AM »
Hi Everyone,
Someone a while back suggested making drawings of the gaskets. I have started to do so and have intake, exhaust and water flange gasket drawings. I will continue to collect them as I take a part off. I'd post it here, but I'm to dumb to figure how to paste it in.
Next is the belt and thermostat
ST gen belt    USA NAPA #250060935    93.5"
             Canadian  NAPA #060935          All Chev 4.3 L,  Ford 90 - 96,  Chrysler Pacifica '02
thermostat
       USA NAPA #THM253  190     Dimensions:1.805" Flange Diameter
Canadian  NAPA #33429     195    Dimension   1.72 "   GM '86 to '02
If you are one of the poor deprived souls who has no machine shop, unlike me ;D Here is a way to install a thermostat without machining. Yup.
You will have to make a gasket for the flange out of .25 gasket material. Make it to the outer dimension of the thermostat rim. Its thickness is .230" Use this gasket to center the thermostat in the head and use a Dremel, air or electric die grinder, to remove a bit of casting on the hole edge so the sensor end of the thermostat clears the block. Slap the flange on and bolt it down. Oh, yeah, drill a 1/16 hole in the thermostat plate close to the edge of the opening part, but not in it. This will let the air thru. If you don't want to, loosen the bolts after you fill it with water, wait til all the air comes out and re-tighten.
Gerry
Re: List of all standard info
« Reply #1 on: January 15, 2006, 12:15:51 AM »
Gerry,
I sure didn't find a 0.25" thick gasket on my Lister. I used silicone coated (George B's trick- works nicely) generic pressed paper gasket material from NAPA.  A place for standards is a great idea.  Include 1 1/4" Taco cast iron circ pump flange as a mate for the breather.  Grainger 4RC79.
Bruce
WWIProps
« Reply #2 on: January 15, 2006, 01:32:03 AM »
Use as taco flange with the mounting holes opened up a bit.  The standard taco 1 1/4" gasket is very thick and allows a thermostat to ride between the head and flange.  There is enough space around the gasket that there is no need to drill a hole and I think you avoid the problem of an inrush of cold water becasue there is a bit of flow around the thermostat.  Worked very well for me.
GerryH
« Reply #3 on: January 15, 2006, 01:42:05 AM »
Bruce,
You are right, my zero is missing. The gasket is 25 thousands thick, the thermostat flange is twenty three thousands thick.
Gerry
GerryH
« Reply #4 on: January 19, 2006, 04:11:24 AM »
Plastigage for the rod bearing clearance measured 0.003, or just a bit under.
Lister 6/1 intake     .017
Lister 6/1 exhaust  .032
CS valve compression ratios
19:1 starting 15:1 running
GerryH
« Reply #5 on: January 20, 2006, 05:06:40 AM »
More info--
6hp or 4.4 kw
Bore: 114.5mm  4.5"
Stroke:139.7mm 5.5"
Displacement: 1431.4cc or 87.34 c.i.
Compression Ratio  18:1
Nozzle Opening Pressure: 2800psi
Injection timing : 21' Btdc
Valve Tappet Clearances cold :  Intake .017    Exhaust .032
Lube Qty 1 1/4 gal  (or till the rod dipper is mostly covered at BDC)
Lube oil  type Sae 30 w  Api CC or better
Cylinder Head Clearance: .045-.050 at wrist pin positions
Ring Eng gap:.022
Ring Land clearance:  .007max
Rod Bearing clearance min .003-.005max Big end
Rod Bearing Clearance Small end .0015-.002 max
Wrist pin diameter 1.250 inches
Torque Specs
Cylinder Head  160 to 170 lb-ft big bolts
Fuel Injector     35 to 40 lb-ft
Connecting Rod  50 to 60 lb-ft
Housing for Main-Bearings    60 to 70 lb-ft
GerryH
« Reply #6 on: January 22, 2006, 01:13:03 AM »
Tappet guides O.D.   1.3740
                     I.D.    0.7478
Tappet shaft   O.D.   0.7425
GerryH
« Reply #7 on: February 01, 2006, 02:39:39 AM »
Bearing info
ST5 Generator 38mm shaft
bearing #6309 on shaft side, #6307 on the slip ring side
Get a  2RS sealed bearing with the C3 clearence
I used NSK #6307VVC3 and NSK#6309DDUC3
ST10 has 6310 and 6309
6/1 crankshaft Timkin tapered roller bearing #32211M90KM1 (thanks, Quinn & George)
n2toh
« Reply #8 on: February 07, 2006, 09:41:37 AM »
anyone know how long the valve stems are for a 6/1?
About 60 years is all it takes to make science fiction a reality.
SHIPCHIEF
« Reply #9 on: February 07, 2006, 05:14:53 PM »
Ashwamegh 25/2 uses a different center main bearing than other twins we have worked with.
The bearing shell measures 2.125 ID. 2.625 OD, 2.875 Long. No flanges, just simple shells with lock pin hole in bottom shell, and two oil supply holes, plus oil grooves inĀ  top shell.
The main bearing bushes on the ends are 2.125", connecting rods are larger; 2.25.
Ashwamegh 25/2 & ST12
GerryH
« Reply #10 on: February 08, 2006, 05:26:02 PM »
n2oh
The valve total length is 6.499 inches on the new spares I have.
kyradawg
« Reply #11 on: February 08, 2006, 06:44:59 PM »
Peace&Love :D, Darren
« Last Edit: August 03, 2006, 04:54:33 PM by kyradawg »
n2toh
« Reply #12 on: February 08, 2006, 07:15:15 PM »
is there room with the stock cam profile or your improved one to run more lift?
