At the time of my last posts, I was getting ready to pour my engine room slab, and concrete block under engine mount. Since then, the slab and block have poured, engine (disasemmbled) was moved into engine room and mounted, room was insulated, wiring completed in house and engine room, and engine was reassembled. After a couple of diversions recently, I finally got back on the project the last a couple of days, and set out to complete the last few details (heat exchanger/radiator installed (change from my earlier plan), fuel tank mounted and connected) and get this thing running. Well, this morning was it, but after alot of attempts, no go. Using Georges CD and site as a resource, I've rebled the fuel lines (a couple of times), to a point where I'm confident the problem isn't air in the fuel lines. Healthy "clanks" can be head from both injectors. Should I be hearing "Clank"?
When trying to start-up near side cylinder, with fuel "paw" in down position, and decompressors under both intake valves, I cranked it up to a very healthy speed, while maintaining speed, I remove the near-side decompressor, and continue cranking through compression strokes. Smoke puffs out of exhaust after each compression stroke, but doesn't start. I tried the same with the other cylinder and noticed compression felt alot greater.
This conceaned me, because when I was reassembling it, I found the head clearance on the far side (from crank) cylinder to be too high, about .095". This, I checked a couple of times using small lead split shots inline with piston pin, torquing head bolts to 170 lbs, then measuring thickness of lead with calipers. I removed two of the paper joint, which got the head clearance down to about .064", matching the other cylinder clearance. This seemed a little high, but at least both match. How does .064" sound to everyone?
Now, if both clearances are equal, the cylinder compressions should be close. Can I measure cylinder compression directly, and if so, how? Sorry for my ignorance here. I've owned other diesels (tractors), both never did much beyond normal maintenance stuff, and fuel line bleeding.
I was also thinking of pulling the heads and rechecking the spill timing.
Another thing I tried was to heat up the room. When I was first trying to start it, the room was about 34 deg. F. engine temp measured about the same. Since then I've gotting the room up to 65 deg. F, engine now measures about 50 deg. F. Still no start.
Any suggestions would be welcomed.
