Scott:
i had a great visit with you today, i only wish i could have stayed on a bit longer (work
for the rest of you
Scott's setup runs really sweet, i was quite impressed with his setup and skills in building his genset
nice electric start using chevy flexplate and starter, very solid
his cooling system is top notch, and his exhaust calms the beast to a level that is pleasant to be around and talk over the note.
he has very little resilient mounting, and the result is a stable machine that does not transmit anything objectionable to the concrete garage floor.
Scott shared his pictures of all the dirt and grit he encountered, and all his teardown and rework to date, quite impressive accomplishment!
as some of you know Scott has an ashwemeh (i gotta learn how to spell that) 25/2 serial 27, mine is also the same engine serial 37 i think.
i had never heard or seen a big twin run so i found it both interesting and quite exciting to see one all hooked up and able to do the job.
i found the trip to be well worth the time, and found Scott to be very knowlegable and easy to talk to, anyone that is in the area should take some time
and go check him and his machine out.
i look forward to going back and spending a bit more time with Scott
thanks again for sharing your time with me,
i was impressed!
ps, yes i am critical of fram filters, but with Scotts setup i am sure they are more than adequate, i cannot see him running his engine anywhere near over the limit of anyfilter
