Author Topic: Valve adjustment???  (Read 5678 times)
Jukebox
Valve adjustment???
« on: January 14, 2006, 01:52:32 AM »
What is the valve adjustment for a 20/2???
kyradawg
Re: Valve adjustment???
« Reply #1 on: January 14, 2006, 02:14:14 AM »
 Peace&Love, Darren
« Last Edit: August 03, 2006, 07:16:51 PM by kyradawg »
Jukebox
« Reply #2 on: January 14, 2006, 02:35:21 AM »
Darren thank you so very much.   This is a new engine and we have not been able to fire it off. Worked on it all afternoon.
Engine keeps trying to kick back on us. Valves are currently set at  Intake = .008  Exhaust = .008
Will give it a shot first thing in the morning.  Thank you again.
« Reply #3 on: January 14, 2006, 03:21:49 AM »
Sounds like an injection issue.
Jukebox
« Reply #4 on: January 14, 2006, 04:03:17 AM »
Thank you Doug will look into that too.
« Reply #5 on: January 14, 2006, 04:07:00 AM »
Early injection....
Huge joke potential here gents.....
GerryH
« Reply #6 on: January 14, 2006, 04:07:02 PM »
Injection is nice...but I'd rather be blown. ;D
Gerry
hotater
« Reply #7 on: January 15, 2006, 02:10:00 AM »
Kick Back??  Can a diesel do that?
Be sure you're following through the cranking strokes.  KEEP cranking.  If it doesn't fire by the time your tongue gets wrapped around the gib key.  YOU set something up wrong.   ;D
Jukebox
« Reply #8 on: January 15, 2006, 03:31:08 AM »
Today it fired off. Reset valves and followed through on the cranking strokes. (It does run.)
Have two tappets that don't rotate so we will have to look into that.
Thanx for all the info.
« Reply #9 on: January 15, 2006, 06:58:18 AM »
Check your injector(s) timing too.  It's a fairly easy job and you can bet they did't spend much time on that  at the factory.  I was shocked at how much mine was off.
Man, the 20/2 must be BIG!
How about a picture????
Best wishes,
Bruce
