Loose wires? UUUmmm, not exactly loose to start with, but the series wound 4 pole rotor of an ST 5 that I have had splices that were not soldered. It worked ok for a while, but when I switched the load-bank on to bring the machine up to about 4 kw the output went to zero after about a minute – one of the twisted-wire rotor splices got hot enough to soften the cooper so that the wires came loose and a little piece broke off. That didn’t do any mechanical damage, but that was a matter of luck. I suppose the spike that must have formed in the rotor when the break occurred may have damaged the AVR, but I won’t know about that until I either replace the rotor or repair it – and I’m waiting for the vendor to either authorize a field-fix by me or replace the thing.
Meanwhile I'm running a spare that has a crappy AVR, bummer!
