I think I need to clear up some misconceptions. I think I've been misunderstood. The new Tier 2 regs go into effect Jan1, 2007. In order to import legally either the importer or the manufacturer must have a certificate of conformity. To apply for the certificate of conformity the engines must have been tested for Tier 2 emissions and passed. At this point either the importer or the manufacturer must pay the fees for the certificate of conformity. The structure of the fees can go in either of 2 ways. For an importer of a very small number of engines there is a limited certificate of conformity. Once you have done all your testing ($$$$$$) and have an emissions test meeting Tier 2 you may pay a $750 fee to EPA for a limited certificate of conformity to import engines, PLUS also pay an "Administrative fee" based on the retail price of the engine for each engine imported. For large importers the fee is $1800.00 for a blanket certificate of conformity for the range of engines tested.
What all this means is that under Tier 1 the engines (GM-90 DI) could be tuned to meet Tier 1.
Tier 2 will require add-on equipment, payment of the $1800 fee, be subject to the $32,500 fine for non-compliance (per engine), and take all other risks associated with importing the engines. This will result in at least a $200 increase in the base price of the engine, and maybe more, depending on what it takes to make it compliant. NOT thousands of dollars. It WILL result in the importer paying Thousands more!
Can you say thanks for the new taxes?
Mike Montieth
Listeroids/USA
