Yes they are Petter bearings....
Not Listeroid and i should have mentioned that too. Most if not all the sinlge Petteroids imported are the plunger pump TRB version.
http://kirloskarapps.kirloskar.com/kirloskar/web/13$5002.html
This is the top of the line in Petteroids, the KOEL DM10. No TRB mentioned here
Look here at Satyajeet. Art first glance its not obvious but the motor on the right is bushed, its gear pump oiled and it has the heavy fly wheel. The TRB engine is the general purpose pump motor. The heavier castings, bigger fly wheel and better oiling tell the story about the engine intended for generators, but you need to know what to look for in the pictures.
http://www.satyajeet.com/de3.htmGangadha, its not hard to tell from the weight of castings and technical info the BB engines are the premium ones not the trb.
http://www.gangadhar.net/diesel_engines2.htmlI have PEC's version of the DM10. My best guess is this is as close to what ever the original Petters were before KOEL began to tinker and pump up the design ( I think its a P series with a little AV and AVB mixed in where common parts could be used. I need to talk more about this with Peter but I become more convinced the more I read about the PH on Peter's webpages ).
Now back to the Listeroids. If the Indians build a premium Petteroids with BB and not TRB then why would we assume the premium Listeroid is a TRB unit when so far as I have been able to tell no one has ever even imported one?
