I have a 1932 5HP CS and it too has a sprocket on one side. 600RPM is the was the original spec of the CS engine. The 5HP engines are getting rare now. The flywheels on mine have markings to indicate it is a 5HP and one of my other 6HP CS's also have flywheels that suggest they were used when the change over from 5HP to 6HP took place.
Emerald
Sorry, I should have made myself a little more clear.
The 5/1 and 6/1 engines were the same, just that the 6/1 was a 650rpm and the 5/1 a 600rpm. What struck me was that they were still selling the 5/1 'badged' version in the 1950's when most people would have asked for the higher output. It is possible that the speed was a factor.
Re your comment about flywheels, there were no other mechanical changes at all, up until the 8/1 came along, then the flywheels changed to the solid type, the change-over valve was removed, the block had cored clearance for the main studs and so on.
The spoked flywheels were always fitted to all the 3/1 5/1 6/1 10/2 12/2 except for generator engines, either SOM or straight drive, in which case the solid flywheels went on. I do not know of any non-generator CS engine that had solid flywheels, but I expect that one will come out of the woodwork now that I have said that! :-))
The flywheel type does vary a lot, but generally a solid flywheel and compression change-over valve indicates a CS engine from a generator set.
The last pair of 10/2's that we had through our hands a couple of years ago were ex-MOD (Ministry of Defence for the overseas guys) and they were both winch engines and both came with sprockets on the crankshafts. One went to Holland, one went to a friend in North Wales.
Regards,
Peter
