Got a 600rpm 3/1 which is in need of some new parts and thus far I haven't found any places which stock them.
This engine was last reconditioned in 1972 when its pump shed got flooded by a river. Since '95 it's been driving an 80amp car alternator recharging a 12v battery bank. It's been reliable as an old shoe and clocks around 2500-3500hrs per year. Worst break downs have been a broken fuel pump governor spring and spilt pin. Hours clocked pre-'95 are unknown.
Current problem is a serious lack of compression and when slowly cranking you can hear it wheeze in/out (with compression on) through the pitted and worn valves. In winter it sometimes needs an air intake shot of Ezy-Start to get going. It's also losing oil out both ends of the crank.
Given its clocked easily 30,000hrs, I doubt new valves and new crank shaft oil seals (assuming this design has them) will be sufficient. Not sure how worn the gear train inside is due access difficulties.
Have already asked Mr Atul Patel but unfortunately he doesn't have any parts for the 3/1.
Have tried finding another working 3/1 or 3.5/1 in NZ but they're just not on the market place, only high speed units or those out of ships, Hmm.
So my questions are:
1: Who stocks parts for this reliable little work horse?
Please post sufficient contact details and what items they have because I'm located in New Zealand.
2: Given how common the 6/1 is, how many of its internal parts are compatible with the 3/1?
P.S. This engine is located about 20m from the house and you need to strain the ears to pick up its faint boom boom boom noise - lovely! (Runs a straight pipe, no muffler) Much friendlier than the high speed 3hp lister it replaced which could be still heard over the TV at 80m!
Thank you very much.
