I just purchased a 14/1 Ashwamegh from Rocky Mountain Power Supply and I'm outfitting it and "hopefully" installing it within the next week. I'm pretty new to this type of engine/setup, but not to generator maintnance, rebuild, troubleshooting, rigging... you get the point. I'm trying to do this as right as possible the first time. Maybe for the last time?
We live off-grid in Idaho Springs, CO. We have an Outback inverter system 2(3648 inverters 7.2kw) and apprx 4200 watts of solar capacity on zomeworks trackers. We also have an outdoor concrete spa and a wood boiler that we use to heat it and the house. Our house is heated via radiant floors with Tekmar controllers and a Buderus wall-hung boiler for back-up. We dont live nearly as energy efficent as an off-grid home should... but hey you got to keep the spa pump going as much as possible. Priorities, priorities.
Here is where I'm at:
1) Purchased a 14/1, 23" flywheel, Ashwamegh from RMPS (very helpful... even with my lack of knowledge)
2) Purchased an 8 groove 11.25 inch pulley from RMPS
3) Purchased an ST12kw head from Joel
I know the 14/1 will only put out about 7-8kw at our elevation 8,600' but I wanted to get an upsize for surge, life, and /or future engine increase. I'll be running this unit apprx 8-10hrs a day in the winter and when needed in the summer.
Mounting -
I'm planning on pouring a cube 30" deep(20" sub-grade)x53"longx30"wide. It will have 1.5" polystyrene between the cube and sub surface soil. It will only be apprx 12-18" from a walkout foundation wall. Any idea if this proximity is a problem? It will be completely enclosed in a sound deadened (house attached) room apprx 8' high 5'deep and 8' long. I'm planning on building a frame out of 3" square, 3/16" tube and bolting this directly to the slab without the use of grout. I will sleeve the bolts in pvc for the top 4-6" to allow for elongation, etc. Any ideas on how to
really deaden the noise with drywall, eggcrates, etc?
Cooling -
I'm going to pipe the coolant thru our wood boiler via a closed loop constant circulation with 100% PPG Coolant. The wood boiler usually maintains a temp of 130degrees (max 150degrees). I'm thinking this will keep it warm for easy starts and when running it should heat up the 170 gallon wood boiler to heat the house, hot tub, etc. Any idea what type of heat I could expect to gain from the enginge?
Gauges -
I'd like to mount some large analog gauges but having a hard time finding any antique looking, big cool ones. Any suggestions what a good assortment should monitor would be helpful. I have a killawatt for elec monit.
48volt dc charging -
In addition to the direct AC from the st12, I want to incorporate a 48vdc charging source running off of the st12 in parralel with the house loads. If I have a large load need that bogs the engine, I can manually drop the ac source coming thru my inverters and then run the load off of batteries (3,600ah VRLA bank) and have a 48vdc charger also providing amps. I can provide more AC kw's from my inverters than I believe the st12 will be capable of.
Fuel Supply -
I want to mount a 55 gal drum to gravity feed diesel for now. In the future I would like to run a coolant heated blend or SVO... but one step at a time.
Exhaust -
I want something quiet and safe. Because of the common house/generator room wall I want something that wont leak ever. (right) Does anyone have a photo of a buried drum exhaust? Does it need to be buried?
Thanks for any suggestions! This forum is great and helped me avoid several pitfalls already. Ed
