Hi Biobill,
There's flex n' there's flex. If you don't mind it leaking and can weld or braze it to pipe nipples just go to pep boys or whatever.
If you want proper stuff, a stainless bellows rated for pressure and temperature, look in the MSC catalogue. (MSC Supply) . If you like I can look it up, but then, so can you. Cat is online in pdf. That's where I got the real thing. Not too pricy either.
Best, Phaedrus
