Newbie here, but what I did with my 24/1 15kw was install a Perma Cool 2 micron filter/water separator (made a wee bracket out of 1/4" plate)...
The starter was a little more complicated, I drilled/tapped the non-pulley side of the ST shaft for 1/2" coarse thread. I put a Grade 9 bolt in there, and spin it up with my 1/2" drill with an impact socket on it. Spinning it like this gives a 2-to-1 advantage (approx), and turns it faster than ya kin by hand... I first tried turning it with a 3/8" drill, and smoked the liddle drill motor... I sit on a shop stool, and brace the 2 handles of the 1/2" drill across my knees, I can easily reach up to release compression lever. If no power to run drill, I have a 12 volt battery with a 800 watt inverter standing by. I think for smaller generators, one could use smaller bolts...
As the engine starts, the bolt backs out - easy-peasy electric start, the El Cheapo way, works every time...
I looked into a portable 12 volt starter from Arrow Engine, it would probably have worked fine, , and not difficult at all to build the required mount into the cradle, but I didn't like the price ($1200).
Richard
