YES! a Petteroid forum is needed.
We are in the middle of trying to get a 3 hp Ashwamegh mini-Petteriod running. Intend to run an alternator/ batteries/inverter setup
Got it from the folks at utterpower.com/ Joel Koch a few months ago.
Lots of sand, they sent other crank pin bushings as the original ones were scored like you would gag over.
We tore it down to the last bolt and cleaned up.
Now we are waiting for aother cam shaft as the timing was irrepairably off, tried to tinker it out with shims under the injector pump and fiddling with clearances, even slipped the timing gear a notch, which helped a bit.
Hoping the new cam shaft will be machined by someone who didn't use some
white powder instead of curry with his lunch.
Can always use the sand in the children's sandbox....
