I'm slowly working my way towards getting a jkson 6/1 and a 5kW ST head for it. It'll be used in an off-grid setup to top up batteries once a week or so, with solar making up the most of the charging capacity. Charge time from flat of the battery storage should be about 8 to 10 hours of full load (3kW) on the 6/1, but I don't expect it to be completely flat all the time... just half the year in monsoon season
. I'm using new nickel-iron cells as - while inefficient - they're immune to discharge damage. I expect the system will be used and abused lots.
Anyway, going through the math involved it seems I need a 250mm diameter pulley on the generator to get 1500RPM and 50Hz at aroundabout 620-650rpm. I'm not completely sure of the flywheel size of the jkson engines - 23.5" ?
So, rough gameplan is :
- Source a 250mm, 8 groove poly-v pulley with a bush to suit the 38mm shaft
- Find a suitably-sized belt and bung the 6/1 and genny together on a solid frame
- Possibly get a small tensioner on the frame as opposed to stuffing around with a slide of some sort for the genny, as I'm sure to screw that up.
- the pulley mob also stock some nice stepped tensioners that also serve as belt trackers.
- Mount frame with fairly solid rubber mounts bolted to a concrete pad. (Fairly solid as in rated at 500kg each rubber mount. It won't be all that flexy. Hopefully)
- Run cooling pipes to a fairly thin tall rectangular cooling tank and let it thermosyphon away. Dimensions guessed at 100cm long by 150cm high x 10cm wide or so - just want plenty of surface area for convective cooling, right? Anyone good with the calcs for this? Ambient is about 20 - 30 degrees C year round. There'll be a heat exchanger in there somewhere to boost my solar hot water system, as when it's cloudy I'll be needing to run the genny to charge the system up anyway.
Anyone see any showstoppers in this?
