btw,, i am regarded as being the "go to guy" for cold weather starting
things that can be used for cold starting, (below zero)
1. fire, a smudge pot made out of a cut off steel drum, filled with oil soaked rags, slid under the truck and set afire!
been there done that.
2. hot air from a space heater, works well
3. starting ether works well in moderation, if admitted to a cranking engine you won't lock it up and damage stuff
4. gasoline in a windex bottle to atomize the spray, works nearly as well as ether, with much lower chance of damage.
5. propane torch lit and stuck down the intake pipe as you crank the engine, will admit heat to the intake air and speed up starting.
6. glowplugs of course do a very good job, and i would not be afraid of installing two of them in a listeroid or a changfa if need be.
7. shelter for the engine is a big help, get it out of the wind, and don't place the shed at the lowest part of the property, that is where the coldest air will settle.
8. insulate you shed, and build it of thermal mass if possible this well help to hold over a moderate temp for easy starting.
9. don't mount the engine to an uninsulated slab if you can keep from it, unisulated slabs are like heat magnets
10. a small shed can be kept above freezing with a 100 watt light bulb, as evidenced by many farmers in their water pump houses.
11. when starting a diesel, set the rack to no fuel (if you have the ability to do so) and crank it over several revolutions, this will allow the cylinder to build some heat before the fuel spray is admitted. fuel spray has a refigeration quality about it. then advance the throttle to fuel position. Detroit advised this method and it works for any engine that you have a cable pull engine shutdown.
just a few of my favorite things....
