Hawker Siddeley was a conglomerate and the parent company of Lister for a few decades. I have not seen much if any documentation about Lister gensets from Hawker Siddeley directly. It will probably be easier to break it down by engine model and generator model.
The smaller tag above the Hawker tag will give you some data though. The 8th-10th digits indicate it is a Lister HL4 engine which was produced from 1983-1991. If I am reading the tag correctly it is the 397th engine produced in 1984 The last two digits which I can't make out are your build number for specific operating data. There appears to be a tag on the generator head which will give you the info needed to track down data from that manufacturer.
