Hi folks,
Long time since last been here. Maybe the reason is, that my engine has been working like a charm. But now, one month ago I noticed one odd behavior with my Lister SR1.
I had it running quite a long time, because I wanted to get my accumulator as full as possible before winter time. My engine was running normally and after quite long time running, I noticed that the half press lever was "pumping" like on and off continuously. I looked it for a while and then stopped the engine. I attach one video to this feed, so you can see, what I am meaning with that "pumping":
My accumulator charging has been set so, that when running, the charging is about 1.2 to 1.3 Amps. I have been thinking, that it might be the right value, but I am not sure of that. Also wondering, might that pumping be the result of low battery voltage or what might cause that behavior. I would be very happy, if some of you might see the problem and send me some tips, how to try to solve it. Thanks in advance folks and hope that your machines work fluently and you are happy with them I have been extremely happy with my renovated machine.
-kari-
