I have a trailer mounted SR2 with an air compressor. I got the setup to do some rammed earth construction. Got the engine running fine, but stopped using it because of problems with the air tamper end, not the engine/compressor end.
Engine is English manufactured in 1972 and has standard rotation.
I cleaned/replaced the injectors to have it up and running. A few non-original parts such as; a fuel tank from an old snowmobile, an oil pressure gauge, basic compressor side things such as a filter and regulator.
Been a couple of years since I last used it and will need a full check over before firing up but I have no reason to think it will not run with minimal work. Stored in a dry desert environment. Located in Eastern California near the Nevada border.
Wanting to sell for $950. If interested you can text me directly at 760-two five eight-66 two five.
Would clean up nicely and be good project for someone. But not me. Too many projects!
Thanks
