Author Topic: 1980's centrifugal water pump, lubrication question  (Read 18327 times)
Portugal lister
« on: October 03, 2025, 03:30:22 PM »
Hello everyone,
I want to ask for some advice on what lubrication this belt driven water pump should have.
I have tried placing a screw driver in the fill hole and the shaft is in the way, i only get a tiny mark on screwdriver tip but it looks to be a clear "oil".
It does not smell like gear oil.
Also the pump has no drain hole in it, only the fill hole, so i assume removal of pump to empty out old 'oil' but then, how much to fill it and with what type of oil.
I have tried searching the make online with no results.
Any advice would be gratefully received as we use the pump regularly and is driven by my Lister CS12-2 which i am about to overhaul so it would be nice to change the oil in the water pump too.
dax021
Re: 1980's centrifugal water pump, lubrication question
« Reply #1 on: October 04, 2025, 09:48:57 AM »
If you are referring to that place where the funnel is, I don't think it is for oil.  To me it looks like a primer hole.
Portugal lister
« Reply #2 on: October 05, 2025, 08:04:18 AM »
HI Dax021
I mean in the 'gearbox' i have circled it. theres a bolt and is where i found some oil on the end of a screwdriver, but have no idea what oil or how much it should have.
And yes the small brass funnel on top of the impeller is the primer.
Alex
dax021
« Reply #3 on: October 05, 2025, 08:22:49 AM »
Sorry, my bad.  No idea how much oil, but at a guess, I would think that there is a felt pad in there somewhere and would need just to be kept moist
Portugal lister
« Reply #4 on: October 05, 2025, 08:32:22 AM »
When i poke a screwdriver in there it hits the shaft and can't feel or see anything else.
Ive been using the pump and wanted to check i wont be burning something out in there if low on lube, from what i read on the net it should either be a grease or type of oil, what i see on the screwdriver is not a grease but looks clear.
Also very odd there is no drain plug only the one circled.
sirpedrosa
« Reply #5 on: October 09, 2025, 10:19:08 PM »
Hi Alex, Gentles
IMMO its a oil sump to lubricate the 2 shaft bushes/bearings.
VP
PS: search for RUTSCHI pump.
« Last Edit: October 09, 2025, 10:20:42 PM by sirpedrosa »
By order:
Petter PAZ1 - Jun 1967, 3HP, sn 416xx
Petter PAZ1 - Nov 1979, 425xx [Kristin gen]
Lister CD [355399] 1937 - on the bench..
dax021
« Reply #6 on: October 10, 2025, 06:58:58 AM »
I agree with VP and would guess that a couple of squirts from an oil can every now and again can't hurt and should be enough
Portugal lister
« Reply #7 on: October 10, 2025, 08:24:04 AM »
Thanks Dax021 and as always Valdemar.
I have contacted both companies by email, Tecnidraulica and Rutschi.
Tecnidraulica replied but told me they have lost all records for this time period. I have not heard from Rutschi yet.
Can i ask what sort of oil would you use?
What is in there now looks clear.
Thanks guys!
dax021
« Reply #8 on: October 11, 2025, 08:52:00 AM »
Just about anything will do.  What's in your oil can right now?
Portugal lister
« Reply #9 on: October 15, 2025, 02:17:05 PM »
Thanks Dax021.
I got a reply from the manufacturer about the oil, he said a 80w90 EP fluid.
What is in there is not that thick so i will put something lighter in there, thanks for the help!
