Hi everybody.
As thread title, i live in Portugal, i bough a farm here 10 years ago and it came with a CS 12-2 installed in a small building, plumbed for pumping water. I owned a garage in the UK so know my way around engines but some parts of the lister's need some special knowledge/ Lister know-how, i think i might be lacking.
So a little intro into my Lister first,
I have been reading threads on here for some time and now i think it is time to give my Lister some much needed care and attention, i will be going back to the UK in a month or so and want to buy parts i need before returning and i am hoping you all might enjoy my journey and also you guys n girls might be kind enough to help me with any tips and advice that you think i might need.
I have the PDF manual but that is about as much info as i have.
Anyway 10 years ago i got the girl fired up, after some initial checks and it ran very well. we only ran it a few times as it took me years to find and then work out the miles of pipe work the farm had, many of it buried.
in the last 2 years i have been using the Lister every few months to fill a 140,000 litre tank we have at the top of the farm, some 250 meters away and with a head of 35 meters, this is run through old cement pipes with 4 inch bore, buried in the ground. it runs for about 4 hours each time.
We have just gone through the biggest forest fire Portugal has ever seen and the old girl worked everyday of the 3 days the fire was around us and we managed to pump over 500,000 litres of water which was used to soak the farm etc and glad to say the fire never got in to our farm. Sadly in 2019 it was not the case and we lost everything we owned due to a huge fire, i lost 5 years of work, fencing and about 3 miles of irrigation pipes and taps and every thing from our UK home was turned to ashes...... i am determined this will never happen again, at least not to that magnitude, and the Lister is the heart of our water supply.
the day after this years fire, one of the cement pipes bust and found a fountain firing out of the ground, fixed that, to then have another fountain 2 meters before that one.... tree roots wERE the cause.
How lucky we were that pipe decided to give out on us one day after the fire was deemed safe in our area.
after those were fixed i had another leak in the main cement pipe again, which i fixed yesterday.
We have no true history to the Lister but a local guy, now in his 70's worked here when he was a young boy of 7 !! and his job was to start the pump alone! and i have feeling it was installed here from new. i have Lister spanners and an old broken crank but this is from a single cylinder Lister in the "pump house"
I have some videos of the pump working which i will put up for those interested and i think it runs very well and starts very well.... but without any history after servicing i want to strip it down and get it back as good as i can get it, for my love of the machine and because we need her to not let us down in our hour of need through lack of maintenance.
The video attached shows the Lister running a quick attempt at fire defence for the Lister, should the fire just gone have reached her.
So on to why i am posting this thread..
When i first looked at the pump 10 years ago, before trying to start her, the oil level seemed high and i would have said it had diesel in the oil, because of this we ran the engine out of fuel each run as i suspected a fuel pump to be leaking, but since told that is very unlikely...is this possible??.. the pumps looked dry but the engine was filthy so was hard to say for sure, hence running it out of fuel each run.
in these 10 years i have probably run the engine a max of 100 hours in 4 hour stints.
In the last week or so i have a small dribble of fuel from the left fuel pump from the little hole at the base.
on its last oil change, (the oil change before i washed out the sump), i found what i think was a tiny piece of babbitt in the sump which worries me and was the point i knew i had to strip her down.
I have posted some photos of the engine, taken 10 years ago and any help on dates would be great as from looking at the Old Timer Engine site and my little knowledge it says 1930 OR if i add the 50 years it would make it 1963 ?
I am thinking of buying.. any advice
A complete gasket set
2 fuel pump shafts, as one is dripping a little
full set of bearings.
The problem i have is i do not want to fully strip the engine down before i leave, unless advised otherwise, so as to leave the Lister operational while i am in the UK to maintain our water supply, this is very important as we have over 50 milking goats and we milk twice a day in the parlour, and water is needed.
Could i take one head off and then re-use the gasket, just in case the pump needs to be started, for when i am away?..... just to look for ring wear on the cylinder and valves etc.
Obviously on my return from the UK i will post here the work i will be doing.
If you got this far into my post, thanks for reading!
Cheers to all
