This afternoon, I was comparing a pair of 6/1 camshaft assemblies. One is an original Dursley, the other is a NOS Listeroid part that was modified by John Ferguson to relocate the lobes per Dursley spec. So far, so good.
I noted that on the listeroid cam, the governor sleeve has a pin that prevents the counterweights from rotating a full 360 degrees on the sleeve. The Dursley governor sleeve (p/N 3165) has no pin. The Dev Engineering part manual shows this pin whereas the old Dursley parts manual shows no pin.
Any information as to why the Indians added this pin? Did Lister add this pin in later models?
Curious.
Hugh
