Author Topic: ST1  (Read 8225 times)
Startomatic
ST1
« on: June 26, 2025, 11:17:43 AM »
Hi all,
i am in the process of acquiring a ST1 with a rather odd serial number prefix....
MY 64 ST1 81 06
can anyone enlighten me the prefix MY?
i am writing from Malaysia and as far as i know, only the 8/1 and 16/2 were CKD here.
meanwhile, can anyone let me know the dimension of the 4 mounting holes at the base?
your input would be much appreciated. thanks!
Lister 6/1 with ST5,Lister SL3, JP1
Yanmar Diesel L10,TS65,TS105 with Interpump hp head
Yanmar 3TN72, NT110 with ST5
Andoria S320
Kubota Z400 Twin Diesel with KEW 1500 hp head
Isuzu 25KVA Diesel silenced Genset
ChangChai EV80
JianDong 1115
Shineray250 watercooled- gasoline
ListerHRW3water
Re: ST1
« Reply #1 on: June 27, 2025, 10:08:25 AM »
Hi all,
MY 64 ST1 81 06
At a guess - it's an export marker; "MY" does rather suggest "Malay" i.e. Malaysia, doesn't it?
Looks to be a 1981 engine (I think the "81" is actually "31", with some somewhat heavy-handed stamping), I'm not sure what the "06" suffix is - could be the build number (which appeared officially on the plate from 1982).
Startomatic
Re: ST1
« Reply #2 on: June 29, 2025, 04:33:03 AM »
Thks for the heads-up.
This is a rather unique unit.
It comes with a thick face 4inch width/14inch diameter flywheel. Even the stub output shaft had 6 holes. Both features I had not seen in a ST.
As far as I can tell, the unit is stock standard,
More pixs to come once I get it home.
Andoria S320
ChangChai EV80
JianDong 1115
ListerHRW3water
Startomatic
Re: ST1
« Reply #3 on: August 01, 2025, 02:36:35 PM »
she is home finally.
my biggest puzzle is the thick flywheel which i had never seen one before on a ST1.
she was almost impossible to stop once fired up as the heavy flywheel keeps her going unless the fuel is cut off till the rotation stop.
and i am a happy man indeed.
Andoria S320
ChangChai EV80
JianDong 1115
ListerHRW3water
