Slow Speed Diesel Engines => Changfa Engines => Topic started by: markymark on December 10, 2022, 01:36:23 AM
hello
when the tank runs dry
or filter change do we have to bleed the injector.
Im sure we do
but no bleeder on injector housing .so im guessing crack a line open?
which one
thanks.
Mark.
You don't have to bleed the injector when you change filters but you will need to bleed at the pump. If you ran it out of fuel then yes bleeding the pump and injector will start it quicker than cranking forever to get it going.
Thank you for the info sir
much appreciated
have a great day..
