Lister Engines => Lister Market Place (things for Sale) => Topic started by: Zero_G on December 31, 2021, 08:32:59 PM
Edited to change quantities of sold items.
Here is a list of the parts that go with the engine that I am selling. Almost all came from Central Maine Diesel. I will sell these parts separately, and adjust the engine price accordingly. Prices are per each except where noted + shipping at cost. I only ship to the USA. No fee payment methods: PayPal F&F, Venmo, Cryptocurrency. Payment +3% methods: PayPal G&S, credit/debit via phone.
YouTube video of parts:
https://www.youtube.com/watch?v=iLtxAADOYRg (https://www.youtube.com/watch?v=iLtxAADOYRg)
3 con rod small end brg, std $15
4 con rod large end brg set w/shims, std $15
3 main brg, sleeve type, std $25 ea.
3 bronze idler gear $120
3 injector, Bosch, complete $70
3 injector pump, Bosch $75
4 gib key set (2) $10
1 gib key puller $50
3 injector nozzle, Bosch $30
3 pump element, Bosch $30
3 pump valve, Bosch $20
3 valve guide set (2) $12
3 valve set (2) $17
3 valve spring set (4) $13
3 rocker arm set (2) $13
1 SOLD rocker arm assy $30
3 2 tappet set $20
1 SOLD wrench set $20
4 3 banjo bolt set (2) $10
1 injector pump tappet $15
3 idler gear bolt $8
2 valve guide seal set (2) $10
2 valve cap set (2) $5
4 valve cup set (2) $5
3 piston w/ wrist pin, std. $40
3 2 piston ring set, std $20
1 cylinder block w/ liner, std. $150
2 cylinder block w/o liner $75
1 head stud set w/nuts $40
2 1 camshaft assy. w/gear $80
2 cylinder liner $75
2 pushrod set (2) $18
2 4-bolt main bearing hsg set (2) $100
3 governor assy $20
1 cam cover w/governor & tappet $80
2 fuel pipe set (2) $40
1 hand crank $22
3 2 fuel filter assy $20
2 small stud/bolt set $10
3 valve cover bolt $8
3 main seal set (2) $15
3 rocker bushing $5
1 fuel lever $5
1 complete gasket set $15
3 head gasket $15
3 cylinder head w/valves $175
Sent you a PM.
Thanks for responding to my questions and for the quick shipment of the parts. Everything was correct. I really appreciate the effort you put into packing everything properly. Thanks again!
sold pending funds.
ALL SOLD
