Lister Engines => Original Lister Cs Engines => Topic started by: veggie on April 05, 2020, 05:03:26 AM
Curious,
I see many Lister CS engines with the outer face of the flywheel unpainted.
In fact some look like they were sanded, polished, and oiled.
Is there a reason for this? or is it maybe tradition. For an antique look ?
Leather drive belts ?
Whoever it was had the CS with the stove black and boiled linseed oil finish (Casey?) - that was a great look
Hi Veggie
Its only to show off. Mines where polished with wire brush, after with scotchbrite, and to finish a coat of polyurethane varnish.
The rim face has the serial number engraved.
If an engine is on duty its better a good coat of paint to prevent rust.
(Casey?)
Nope; Not me.
My guess would be to reduce chips of paint being knocked off and to add a bit of snap to the appearance.
What was the factory solution?
All painted green. Original 1974 startomatic in original uncleaned condition.
(https://listerengine.com/coppermine/albums/userpics/10039/normal_Flywheel.jpg)
Mick
I's say it's because it's a satisfying finish easily obtained with emery cloth one the machine is running.......
