Lister Engines => Original Lister Cs Engines => Topic started by: queenofjacks on January 10, 2020, 06:17:12 PM
Title: Over size piston rings?
Post by: queenofjacks on January 10, 2020, 06:17:12 PM
  I'm wondering if I should bore the cylinder of an 8/1 that I am overhauling  and if so how much?  Are oversize rings available??  Any info would be greatly appreciated.  --- Thanks
Title: Re: Over size piston rings?
Post by: Hugh Conway on January 10, 2020, 11:31:42 PM
For a Dursley, oversized pistons & rings are available and the cylinder can be rebored. Here's a source:
https://www.stationaryengineparts.com/-Cylinder-piston-rings-and-con-rod/
For a listeroid, it might be better to replace the sleeve and use standard size piston and rings.
Post by: listard-jp2 on January 11, 2020, 09:32:31 AM
Why take chances on questionable quality Indian sourced items, when you can have a genuine UK manufactured item?
https://www.ebay.co.uk/itm/LISTER-CS-NOS-GENUINE-NOS-HEPOLITE-COVENTRY-PISTON-BACO-OVERSIZE-VA-6-1-8-1/254185213781
