Lister Engines => Listeroid Engines => Topic started by: Mtour on December 01, 2019, 12:20:22 PM
Hi
Not sure if these bearings can be run in this condition, all the research I could come up with seems to point to that these bearings seldom fail.
Run or replace.... Thanks..
Hi
Looks to me your bearing was installed with an improper preload
https://youtu.be/iQpgH7K2_t8 (https://youtu.be/iQpgH7K2_t8)
Thanks for the reply..
Could be, the crank would not rotate heavy side down without help. The piston, idler gear disconnected with the flywheels off.
Check:
1. Bearing preload.....
2. Then crank runout....
Those bearings are ruined and need to be replaced.
Should be some numbers embossed into the bearing parts, use those numbers to cross over to a known manufacture with a well earned reputation for quality.
thanks...new bearings purchased..
