Slow Speed Diesel Engines => Changfa Engines => Topic started by: Halfwalker on November 10, 2019, 08:33:36 PM
I have an old 295/2100 ChinaDiesel generator, about 15 years old or so. In general, it has run pretty well, lots of oomph, and always started up fine after a few seconds of churning. About 5 years ago we had a run of good weather, or the power company kept their lines well, because we didn't have any outages that required the generator (I have an inverter with big batteries). Power would come back, batteries would charge back up and all was well.
So a couple of years ago I did some improvements ... Ran a 3/8" copper line through conduit down from the heating oil tank - no more refilling that silly tank on top of the genset. I removed that tank and the associated "instrument panel" of useless gauges, wired up my own set of gauges, etc. All looked OK.
Except that the damn thing wouldn't start. No matter what I did. Frustrated, I gave it up for a while, but have now come back to get it running again.
I've heard that the fuel injection pump can sometimes go bad, and I have a sneaking suspicion that may be the culprit here. I mean, it's a diesel - give it fuel and air and it runs, right ? So I though to pull it off, take it apart and see what I could see. BTW, overall the engine is crappy design - hidden/blocked bolts means you have to remove other stuff first.
I have the 3 bolts that hold the main injection assembly to the engine out, and the assembly is loose, can be rotated. That required removing the front plunger assembly since it blocked one of the bolts. But the assembly wouldn't come off. So I removed the oil-filler neck, which required removing the damn water pump feed because one of THOSE bolts was blocked.
Removed the big nut inside there, but the assembly is still stuck. It rotates fine, but won't come out. I'm loathe to put too much force on it ... Sooo, after that long ramble, I guess these are the questions :
How is that injection pump assembly removed ?
Any tips for disassembly and possibly repair ?
A source for parts ? Millions of these were made, must be easy(ish) to get once found.
(Hmm, can't seem to attach images. It says "uploading" then just refreshes to a new "New Topic" page" and nothing happens. Maybe I can edit the post or do a reply to include the images ?)
(Ah-ha. Images were too big. Resized down now)
look around this site for a member called glort. He has a collection of engines and he's knowledgable if somewhat verbose
I think the 2 holes you are asking about may be for using with a puller.
I found the thread by Boxelder in https://listerengine.com/smf/index.php?topic=8248.0 I'm hoping he might chime in here.
For a puller - of course. Who woulda thunk they would think ahead like that ? I can't find any docs anywhere on assembly/disassembly though. Light tapping with a soft hammer on the end of the shaft doesn't budge it, and I don't want to whack on it too hard.
If I can't get anywhere with it this upcoming weekend I'll reassemble and be really thorough with bleeding all the air out. I did notice when rotating the assembly that oil came out of the hole where the plunger goes, not much. Looks like it needs to be oiled, but I don't know how much.
Hi Halfwalker
Your IP must come off smoothly without any puller.
Have you taken off IP pinion? If so, you must get the IP right timed.
Just my thoughts by now!
Regards
PS: those threaded holes are not for tightening the IP?
PS2: Post more pics please.
No, I haven't removed the injection pump pinion - I'm assuming that's the bigger gear that the shaft is in ? I'll get more pics on Sat - I don't get home till after dark and lighting is miserable out there.
I've just realized that the rotation of the whole injection pump assembly is how it's timed ... Re-reading the "Adjust of the Advance Angle of Fuel Delivery" section in the manual indicates that you have to loosen those 3 bolts holding it to the engine and rotate it to set that angle. Well, those bolts are out and I've rotated it a few times while trying to remove it ...
So this weekend will re-assemble it all, then try to fully bleed the system of air. I haven't found anything to indicate how much oil should be in the injection pump yet. When I rotated it with the plunger off, a small amount dribbled out. I read *somewhere* about someone filling it till oil came out of the vent ? I think ?
Ah ha - found a video sort of about it. It's almost the exact same injection pump as I have
https://www.youtube.com/watch?v=vTAmjyfddvI (https://www.youtube.com/watch?v=vTAmjyfddvI)
Well dang. Double dang. I did the cardinal sin .........
Dropped a damn bolt down that large opening. I managed to fish the washer out with a telescoping magnet, but can't find the bolt. I think (hope) it may have dropped all the way down to the oil pain. I think I can drop the oil pan without TOO much trouble. If it's not in the oil pan, that means it's stuck up higher, and I may have to take the front plate off the engine to get to it. Which would be a major pain ...
This is the exact genset I have - https://www.youtube.com/watch?v=mLXWlOPgDCk
<sigh>
Hah - I bought a bore-scope (cheap flea-bay Chinese item) and was able to fish out the bolt :)
So, finally started re-assembling things. One spec I can't find is what kind of oil to use in the fuel-injection-pump. What dribbled out when I was attempting to remove it, and what can be seen in that video linked 2 posts above, both show it to be a fairly thin type of oil.
Any ideas ? I'm pretty sure not to use regular 10W-30 diesel oil ...
purely a guess, but isn't a fuel pump lubed by the fuel ? That's why a lot of diesels needed repairs when USA changed to low sulfur diesel, the fuel lost a lot of "lubricity" and pumps and injectors started failing.
If you think some sort of oil was sealed in it, maybe Mobil 1 synthetic 0-20W would do the trick
Hi Mike
Some IP are lubricated by fuel (diesel or WVO [this last too thick to lubricate]) if IP is rotating type IP, just 1 plunger.
But if IP is inline cam (multiplunger) with lobs acting in plunger element, they are lub by oil, thin oil.
Take a look at Bosh and CAV tech. Bosh (some) are lub by fuel (others, i.e, kiki (nippon bosh) are plunger). CAV (I think) are most multi plunger.
Just my thoughts.............
