Lister Engines => Listeroid Engines => Topic started by: oldtime on May 07, 2019, 11:43:11 PM
Hi all I have seen a couple of fuel filter mods for the original Cast iron fuel filter .
I want to know what fuel filter people are using . I can do the machining but cant find a suitable filter .
My local filter place was a total waste of time . thanks to all
I have zero experience with the JP engines but if the filter housing is similar to a CS I have a couple modifications that will work or you can with a RACOR in line unit and have superior filtering
Hi Oldtime
Take a look of my update of the cast fuel filter: http://listerengine.com/smf/index.php?topic=8320.msg97805#msg97805
And 38ac has also a good one, look here: http://listerengine.com/smf/index.php?topic=7359.msg83177#msg83177
Another one: http://listerengine.com/smf/index.php?topic=7359.msg83177#msg83177
BR
that's is what I want to do .. Any idea of the filter number . I can make all the bits just the filter number is what I need ..
Hi Oldtime
take a look at the same thread here: http://listerengine.com/smf/index.php?topic=8320.msg97812#msg97812
If you work with imperial mesures you rather follow Ac38 advice.
BR
