How to / DIY => Generators => Topic started by: 32 coupe on September 13, 2015, 05:01:47 PM
I purchased a new 7.5 kw head and it has the dreaded
imbalanced load noise.
I remember reading links about somesort of coating you guys
use on the inside to protect the "guts". Seems like I remember
reading it will help the balance noise. Gryptal .....is that it ?
Maybe a link to to method ?
Thanks for your time,
Gary
There are several commonly available insulating varnish/epoxy coatings used for the purpose... Glyptol is one of many. Take a look in McMaster Carr for their product, we often use them for the supply.
Grainger carries ii too.
I've not heard of red electrical varnish curing the imbalanced load noise problem.
Bruce,
Mine has a noise like loose or vibrating metal laminations.
Found and ordered Glyptol ....I'll see if that fixes the noise.
Gary
