Lister Engines => Things I want to Buy => Topic started by: Craig on December 15, 2012, 10:22:43 PM
I have a chance to buy a 2002 3 cylinder perkins diesel driving a 12Kw Mecce Alte generator head. Seems to run well. It has 5679 hours on it. The current owner had it at his camp and put all but 400 of the hours on it. He says he kept up with the oil changes etc.
I have 3 questions. Is 5679 hours a lot for a Perkins diesel? How many hours are they good for before needing an overhaul if well maintained? Is Mecce Alte a good brand for a generator head?
Thanks, any and all information appreciated.
-Craig
Perkins has a strong history of solid performance and 6000 hours is not much more than 50% service life between overhauls even for a pessimistic outlook. Caterpillar used quite a few Perkins diesels in their small generators and their reputation is sound.
We do not necessarily like the MeccAlte heads, but mostly a matter of ready supplies and personal preference, not any performance related issues I am aware of.
I would take a fairly careful look at water pump, belts and hoses at this hour count. Are the exhaust ports clean and uniform? Does it start easily with minimal cranking? Clean filters? Clean lube oil? Priced right?
In need of a water pump? Check www.fdrbp.com
Thank you both for the info. The seller has gone dark on me so it all may be moot anyway.
Thanks,
-Craig
