Lister Engines => Listeroid Engines => Topic started by: guest23 on August 09, 2009, 10:44:31 PM
I have an Ashwamegh 6/1 with about 1000 hrs on it. I now have antifreeze getting into the oil. I think it is probably the o rings on the cylinder. I am getting ready to tear it down. Is there anything else to look for while apart? Where is the best place to get parts?
Brian
Big end bearings. Antifreeze eats white metal.
Regards, RAB
don't take it apart until you know where it is leaking
take the crankcase cover off, drain the oil
and add a bit of pressure to the cooling system by whatever means you
have.
then with a good light and a small mirror look around in there to determine where it is seeping in from
might be one or more of the cylinder studs leaking past the threads, could be the liner orings if it has ever
been overheated, or maybe oring mangled on installation?
or it might be a casting flaw
better to check what it is together before you take apart and destroy evidence
otherwise you might not find it and have to put it together again to find the leak
Bob is absolutely correct.
My Ashwamegh was leaking from the cylinder studs. That means you don't have to tear down the engine.
Just drain the water, untorque the studs, remove them one at a time, reseal the threads and reinstall. You might have to lift off the head to double nut the studs (to get them out), but you won't have to disturb the cylinder. Consider it an oportunity to de-carbon the head.
Then retorque.
Also, was the base gasket mentioned? It's made of paper, and might be leaking. In this case, you could lift the cylinder enough to change out the gasket with an new one(s). You can split the gasket(s) at all the holes, and use sealant. You need to take compression height readings and add or subtract gaskets to get the correct value for your engine and the altitude it operates.
If you do lift the cylinder, be sure to put too many base gaskets in before checking the compression height. Then tear out the excess ones untill you are in spec. I made mine out of manilla folder stock from the secretarial supply store.
Here is bottom view of sleeve and cyl studs. Should be no prob. seeing where the water is coming from.
(http://s655.photobucket.com/albums/uu276/Tijean_photo/)
Antifreeze is leaking by o rings on cylinder liner and bottom ring on cylinder is broken. I am going to get new rings and rod bearing and gaskets and it should be as good as new. I don't know how the o rings both are broken, maybe poor installation. I am also going to put new rings also. What is a fair price to ask for the complete unit with generator? I may possibly get a larger unit probably about 8k.
i had the same problem with mine. it was the head gasket so i went with a gasket to go head gasket and never had a problem after.
