How to / DIY => Everything else => Topic started by: Bluecometk on August 25, 2007, 09:24:01 PM
Can you use a filter like a Racor 225Rm or R26 (normal vacuum side filter) with a gravity feed injector pump on a small air cooled Yanmar 10 HP diesel? Given a normal gravity feed position.
I would think the necessary flow rate needed to run the 10 HP diesel would be less than 2 Gal per hour. But that's just a guess.
Thank you in advance
Bluecometk.
10 hp yanner i llike air or water cooled you have a fine piece. the consumption rate of dino should be no more than 1/2gph. that would be runnin hard racor should be able to suit yuor need
Sorry for the late reply. It is likely that it willl work when properly bled.
Remember that injector pumps are just that, pumps. While your engine is gravity feed, it is not in the same sense as a carbureted engine. The injector pump will create a small low pressure pulse which can help to move fuel. Some engines are better at this than others.
I'm not all that familiar with the Yanmar but it seems to me they have lift pumps? If not you could get one at a parts store. Some are very reasonable and fairly cheap. I was reading on a biodiesel forum about them the other day and there were quoting a price of $30 with no failures. I have all the links to that site at work. I think it's biodiesel.infopop or something like that. They use the pumps on two tank veggie systems.
