Author Topic: LR1 High Speed Shaft Oil Seal  (Read 1310 times)
Cockie
« on: October 16, 2019, 05:54:48 AM »
Can the oil seal behind the cast aluminium fan be removed without removing the crankshaft? I am having problems removing the lube oil pump pressure relief valve and the main bearings seem to be OK, so was just going to change the big end bearings and the seals on the output shafts. I only intend to use the engine as a display so it won't see a lot of work.
