I decide to start a thread on my build. Originally I was going to build a 6/1 with an ST5 gen head. After talking with Gary at D.E.S. I went with an 8/1 and a Stamford clone generator. It seems like there is allot of work to get the ST generators working good and I thought it would be best to just go with a turn key head that has know clean power. Its much more $ but its worth it for me so I can focus on getting the motor dialed in.
I'm thinking of running this thing in a dual speed configuration. 300-400ish RPM for 12v/24v DC charging and/or running a belt drive vacuum pump for my freeze dryer. 850 RPM when running the genhead.
Something to consider if your going to order a kit on a pallet, make sure you have a forklift to unload or pay for a shipping truck with a lift gate. There is no way to unload the pallet and lift out by hand. The short block with the wheels on and the gen head are way to heavy. The gen I got weighs 200lbs.
Mine came as a short block in a crate on a pellet with all the parts boxed up
After I removed the pallet sides I took off the flywheels. I used a bolt and nut to put pressure on the keys to remove them. They where pretty tight so I gave them a gentle shake while they where under pressure with an air hammer. It took 4 consecutive length bolts to get them loose enough. After I got the keys out, I scrapped the paint off the shaft and gave it a light sand with emery cloth and oil till they where clean before removing the wheels. One flywheel came off easy the other did not. I used a bottle jack carefully placed against a strong part of the case(under light pressure) while taping with a rubber mallet on the opposite side. It took about 20 mins to get the second flywheel off. I had a second person helping me.
So far this clone is looking pretty good for a listeroid. I'm going to start stripping the out paint off and taking it completely apart
I'm going to tear it down and clean it up here at work. I'm a mechanic and can work on it when I'm not busy. I will assemble it at home. I took the genhead home to wait for the motor to be finished. This stamford clone looks very well made so far. Pulley looks to have some good weight to it. Its rated continues duty @8.8kw. Its over kill for my motor and should give many years of good service
This will be a slow going build till I get caught up on another project.
