Author Topic: lister petter ac1w starting problem  (Read 2114 times)
carl159
« on: September 27, 2019, 05:47:10 PM »
Hello Everyone. I've just bought a boat with a lister petter ac1w engine. Managed to start it at first, after a lot of cranking over. Just had the injector reconditioned, fitted a new glow plug and a fuel filter. Now can't get it started. it has a new battery. but it seems to turn over slowly. Any advice would be great. Thanks Carl
dkmc
Re: lister petter ac1w starting problem
« Reply #1 on: September 27, 2019, 08:33:46 PM »
Sounds like maybe you need a new starter.
But before that....
Make sure the bat. cables are adequate size, and the ends are clean. NO battery ends that simply clamp the cable! Only large gauge cables (as large as you can afford if yours are real small or tired) with molded on lead clamps. Connect the ground wire as close to the starter as possible. Check all connections for corrosion and tightness. Install the largest battery possible.
I got a good deal on a Skid loader once with a 'worn out' Kubota 3 cylinder engine. The only thing 'worn out' was the electrical system. Small inadequate cables with shoddy end clamps, poor ground, etc. I bought the largest gauge cables I could get, and a big battery with 850 cold cranking amps. Then I had a new engine! Or so it then started like one.....and never fails to light off quickly to this day.
carl159
« Reply #2 on: September 28, 2019, 06:00:38 AM »
Thanks for the advice
