Author Topic: oil seal Lister CS8-1  (Read 6272 times)
vegoil
Re: oil seal Lister CS8-1
« Reply #15 on: September 28, 2019, 02:04:21 PM »
Is there any of the governor linkage or anything else inside the governor case that has to be disconnected before I attempt to remove the case. this explanation may be helpful to anyone else that has the same problem.
cheers John
« Last Edit: September 30, 2019, 04:37:53 PM by vegoil »
listeroil
« Reply #16 on: September 30, 2019, 03:13:09 PM »
No need to remove anything inside the case if all you want is the case off to replace the seal.  Just the 3 studs and injection pump pipes and a clevis pin on the external linkage.  Good point about aligning it with one of the flywheel holes before you start
Mick
listeroil
« Reply #17 on: September 30, 2019, 04:27:22 PM »
It might be a good idea to remove the injection pump before you try.  It was about 10 years ago when I last did it and I cant remember if I removed it first.  Its only a couple of bolts anyway and easier to do when connected to the engine.
« Last Edit: October 01, 2019, 04:30:37 PM by listeroil »
