Author Topic: Flywheel Bolt LR1  (Read 3135 times)
Avondale
Flywheel Bolt LR1
« on: August 19, 2019, 02:49:01 PM »
Hello
I would like to remove the flywheel on my LR1. I see that it has a 2 1/4" AF bolt (57mm)
I dont have a socket that size so decided to look for one on the usual websites. Not only do they seem quite rare, they are expensive - £40 plus
How do members get these off?
sirpedrosa
Re: Flywheel Bolt LR1
« Reply #1 on: August 19, 2019, 03:32:17 PM »
Hi Avondale
Welcome to the old stuff aboriginal world. It's not only the socket you need, you will need also a torque wrench to snug nut to the OEM spec. And other rare parts, expensive at this time.
The word of order is digging and scavenging.
Have a good week
VP
PS: a M28 socket cost me today 10€, to fit 1.1/8" Lister CS head nuts.
By order of firing up:
« Reply #2 on: August 20, 2019, 05:52:42 AM »
Unfortunately you do need the right size socket so start asking about with your friends or see if you can hire the size you want. If hiring, you will want to be able to remove the flywheel and bolt it back up on the same day so you don't have 2 days hire.
Out of curiosity why do you need to remove the flywheel?
oldgoat
« Reply #3 on: August 20, 2019, 01:06:44 PM »
You could also make one. Mine was 3/8X1/8 flat welded in a piece of 65mm pipe and an old socket welded in the other end for the 3/4 drive. You're probably only going to use it once or twice.
« Reply #4 on: August 21, 2019, 07:27:25 AM »
Maybe there is an automotive FWD socket that is the right size, that's what I had to get for my battery terminal bolts
Cockie
« Reply #5 on: September 20, 2019, 04:31:31 AM »
Avondale, I have the same issue, and I'm thinking of making a flogging spanner out of 10mm flat bar. Cockie
« Reply #6 on: September 20, 2019, 01:30:54 PM »
Any garage that works on trucks would have a socket most of these guys are pretty helpful I don't think borrowing one would be difficult.
Cockie
« Reply #7 on: September 24, 2019, 10:26:15 AM »
Avondale, made up a 56mm spanner out of 6 X 75 flat bar, I was going to add another 6mm thickness, but a couple of taps the bolt moved, it's a 2 and 7/32 or 56mm nut on the LR1 but the bolt id about 3/4" diameter. Hint on getting the flywheel off the taper, align the keyway with  where you might be able to get a hit behind the air duct, I used a piece of timber to protect the fly wheel, a couple of good slogs with a lump hammer, then turn 180 deg, and hit again, that way you are not fighting the key, I got heaps of crap from the air ducts, and accumulated garbage off the fan.
