Author Topic: Roid Bearing Quality?  (Read 6894 times)
StrawHat
Re: Roid Bearing Quality?
« Reply #15 on: August 25, 2019, 06:35:45 AM »
I'll bet some of those babbit Lister engines were the ones that have been reported to have lasted 40 years without serious internal maintenance.
Pretty much the entire steam engine era ran on babbit up to the early 1900's. Then came oil engines and early "glow tube" petrol engines. Note that oil engines are not true diesel engines. The compression ignition engine came along later. Not sure if Rudolf Diesel is the actual true inventor of the compression engine, but he perfected the idea into mass production.
Oil engines became popular at one time, taking over a lot of jobs once done by steam engines. About the best thermal efficiency from the best piston steam engines was only 6-7%, the oil engine almost immediately jumped to 12 %. Double that of steam. This ushered in internal combustion as the favorite power source of the time. Then came petrol engines with even better efficiency, especially after the spark plug was invented, and then the compression ignition engine with the best fuel efficiency.
An interesting European farm tractor (forgot the name) using an oil engine had no reverse gear. The driver simply cut the fuel, waited just before the engine completely stalled, hit the fuel again and the engine restarted in reverse. Those engines ran equally well in either direction! While those oil engines would run on just about any oil that would burn, they still only got about half the efficiency of an indirect injection CS Lister. They use an entirely different principle than compression ignition engines.
Hi Strawhat, grinding bearing races to fit an unusual or no longer available bearing size is very good advice provided you have access to a grinder and you keep the coolant flowing, wouldn`t want to alter the hardening/tempering with excess heat. Sadly I do not own a grinding machine. Many years ago I did have a lathe with a grinding attachment that would have been perfect for this situation. I tried not to use it too often as I was concerned about the amount of abrasive dust it deposited on the lathe sliding surfaces.
Yes, a lot of Lister engines have babbit filled bearings. I have only had to pour a new babbit bearing once on a very old saw milling machine, The trick is to coat the shaft with carbon from an oxy/acetylene torch with the oxygen turned off, once the shaft is well coated with soot, turn on the oxygen and warm up the bearing/bush housing, now pour your babbit. The soot will prevent it from sticking to the shaft.
Hi Glort, I have used head warn lamps a lot in the past and they are an excellent addition to any tool box, I used to keep a rechargeable LED set in the glove box of my UTE, when I got a flat tire at night it was invaluable. I have also used the cheap plastic safety glasses with the bifocal magnifying lens at the bottom. If I remember rightly, they come in five different strengths depending on how bad your eyes are, I guess I would need a number 5 now!  :laugh:
« Reply #16 on: August 25, 2019, 09:39:10 AM »
Herbert Akroyd Stuart is the man you're thinking of, well worth a read up.......
Cheers Stef
« Reply #17 on: August 25, 2019, 10:09:27 AM »
Hi StrawHat, I don`t know what it is you are trying to achieve but if you want an engine that will run 24/7 for the next ten years then the Lister CS is about as good as it gets. These things were built to last forever, all the spares you could ever want are still available. You should contact Gary (aka Dieselgman) and find out what he has available, 38ac might also be able to hook you up with an original CS.
I am lucky here in Australia because Rob at Old Timer Engines keeps every spare imaginable. He also buys and sells old stationary engines, some are just for garden ornaments and others he strips down and recycles the parts. I still think you should check out Gary at Diesel Electric Services. Sadly he does not post much here anymore, not because he is disinterested but because the US law has made it illegal for him to advertise servicing of engines that no longer meet the government emissions standards.
I believe the best efficiency of any engine is now held by the common rail diesel engine, sadly VW/Audi fiddled the emission figures and gave diesel engines a bad name.
« Reply #18 on: August 26, 2019, 08:05:48 PM »
Bob,
Gary has his reasons for not being on here much but that isnt one of them as it is entirely legal for him or anyone else to rebuild or sell parts for an older diesel engine and advertise those services. Certain manufacturers have made deals with the EPA where THEY will not supply remanufactured engines that do not meet current regulations and they must destroy and cores that are turned in to them.  These manufacturer deals do not affect the aftermarket in any way.
« Reply #19 on: August 27, 2019, 01:40:30 PM »
Hi 38ac, I`m sure Gary posted on here a while back that he was having advertising/selling issues with the EPA, but what do I know I live in Australia.
I do hope he is not suffering the sort of health issues that effect us all at our age, please pass on my best wishes and tell him the forum is missing his knowledge and insight.
« Reply #20 on: August 27, 2019, 03:00:01 PM »
 Hi Bob,
Unless I missed something, entirely probable Gary answered a question as to why he didn't expand his web presence and update his web site with by saying he didn't want or need unwanted attention to his clone parts business.
Truth of the matter is interest in India engines is just about done due to low cost solar, EPA, quality issues etc as the fellow at Boltan Equipment will soon find out.
Another large factor is I would guess that fully 90% of people who bought Listeroids never did anything useful with them and they are just decorations in the shed or garage. A lot of people are tired of looking at them and there are quite a few for sale, often at bargain prices.
Gary is well, just spoke with him yesterday via email.  The subject of this forum wasn't breached, I have no insight as to why he has left.
sirpedrosa
« Reply #21 on: August 27, 2019, 11:10:00 PM »
Hi Bob and Butch
I think I know why.
Recently I read all the topic of the "import from england". what a mexican novelle (2 years!)
And I think some sort of mistrust landed in Gary's lap with some LEF members breaking the joint venture of the endeavour.
And that can kill the amusement of posting, among other vicissitudes I don't need to describe... like understand antipodean humour (quote).
We must respect our diferences... All of them! Cultural, age, life experience, social awareness... and 1000's of others.
Giving an exemple: I need a stock key 9/16*5/16 paralell. USA suppliers can't sell it to me because of export fees, and I can't jeopardize a friendship to circumventing this situation.
While we talking here together, about  - most of all antiques that does't complie to EPA's (worldwide) but indeed are priceless for us - and fulfill our will of living, and maintain healthy mind - the real world just want a quick enrichment no matter how, nor who.
Just my thoughts. Do not censure me ...
Have a happy life, please.
VP
By order of firing up:
StrawHat
« Reply #22 on: August 30, 2019, 04:56:36 AM »
Bargain prices? Most people selling these things are on fishing expeditions trying to get a bite on ridiculous prices. P.T. Barnum would be proud of anyone selling scrap iron for $3.00 a pound when its only worth $0.20 a pound at the most.
