Author Topic: Lister help  (Read 3930 times)
Lincsrob
Lister help
« on: August 09, 2019, 09:23:05 PM »
Hi there I’ve acquired a list of stationary engine and I’m trying to work out which model it is please can someone help I will try and attach a photo, regards. Rob
Lincsrob
Re: Lister help
« Reply #1 on: August 09, 2019, 09:26:27 PM »
Hi
Lincsrob
Re: Lister help
« Reply #2 on: August 09, 2019, 09:30:03 PM »
For some reason it’s not letting me post a pic of my engine :-(
Re: Lister help
« Reply #3 on: August 09, 2019, 09:41:09 PM »
G'day.  Maybe image size?  If you use whatever Picture Manager app you have on your device so that your image is sized to appear at 100% when it fills most of your screen - then it's a good size to view and a good size file to upload (save as a JPEG) using the "attachments" function at the bottom of the dialogue box in which you type - see below?  Cheers
Lincsrob
Re: Lister help
« Reply #4 on: August 09, 2019, 09:59:58 PM »
I’ve tried cropping photo and all sorts.  I’ll keep trying lol
Re: Lister help
« Reply #5 on: August 12, 2019, 06:38:45 AM »
I use Windows Picture Manager and 'compress' the image not crop as cropping does not compress the pixels to suit Forums. I compress to being a ''document'' size image and this allows me to post 3 images at a time.
Re: Lister help
« Reply #6 on: August 12, 2019, 09:53:27 AM »
FWIW.  When an image is displayed on your screen, somewhere there is a little box telling you it's displayed at, say, 20% or 30% or whatever
Also somewhere on your computer you'll have an image management programme.  If you right-click on the image file and select "open with", it will probably give you some options
A couple of suggestions:
Open the image in the image-management application of your choice
Somewhere in the "edit" area there will be an option "resize"
If the image is currently displaying at, say, 25% to fit on your screen - then resize it to 23% or 24% and you'll find it now displays on your screen at 100% or close-enough.  Save it as a JPEG with another file name to distinguish this small image from the original
In terms of the number of bytes of digital storage the image occupies - you will probably find it's now 1/10th or 1/15th or some such of the original digital file size
I would think that if you upload it to the site using the "Attachments and other options" feature just below the dialogue box where you type your reply/message - it should load easily and open as a fits-on-a-page image
Just saying . . .  Cheers
sirpedrosa
Re: Lister help
« Reply #7 on: August 12, 2019, 10:00:08 AM »
Hi
Just manage any image to be 950 (Max) pixels wide, and it  fits good.
VP
By order of firing up:
Re: Lister help
« Reply #8 on: August 12, 2019, 12:37:02 PM »
There should be a little date plate on the engine something like attached photo. If you cannot manage to put a photo on here you can add it to dropbox or photobucket etc.
onkelheri
  • "mens sana in carburetor sano"
    • https://www.flickr.com/photos/22328570@N02/albums
Re: Lister help
« Reply #9 on: August 13, 2019, 07:01:21 PM »
Hello everybody,
It's happened right ... at the classic car meeting in Prüm, a Lister N° 245DHZ10 strayed in my birthday basket ... spurred on by the funny "Steampunkmopet" Lister I stumbled on a Dutch exhibitor about it.
Now I search engine data and technical documents about it ... the WWW / google unfortunately does not give so much ...
Greeting Heri
You can see the running engine ,ok only the Pullywheel on the left site for a second ;.)
https://youtu.be/06t-VdjstFI?t=1503
« Last Edit: August 14, 2019, 11:50:21 AM by onkelheri »
Re: Lister help
« Reply #10 on: August 14, 2019, 07:30:04 AM »
G'Day Heri,
So what do you require? A manual? If so we would need to know what it looks like (a picture if possible) and any model numbers and serial numbers to find a manual for you.
onkelheri
Re: Lister help
« Reply #11 on: August 14, 2019, 11:53:44 AM »
Hello Cobbadog,
thanks for an answer: the N° is above ... i highlightet it green right now :)
...the ordered Book is this :
https://shop.kelsey.co.uk/product/BKSLISTD/lister-d-type-restoration-book
and yes i#am still interesset at all the other information - spezial the Age of that Engine.
Greetz Heri
« Last Edit: August 14, 2019, 11:58:47 AM by onkelheri »
sirpedrosa
Re: Lister help
« Reply #12 on: August 14, 2019, 11:45:09 PM »
Hi Onkelheri
Your engine number shows: 245DHZ10
245 it's engine number in the year of production;
D, stands for model D; H stands for hopper cooling; and Z stands for anticlock fly rotation.
And 10 means 1950+10=1960
Take a loock here: http://www.realdiesels.co.uk/identify/buildnos2.jpg
VP
onkelheri
Re: Lister help
« Reply #13 on: August 15, 2019, 01:25:36 PM »
Thanks 1960 times :) Sirpedrosa:
so the netherlandguy whas right with the 1960 information, but he was'nt shure about it.
Now i think about what i should do with it and close to the ListerSteampunkbike https://www.youtube.com/watch?v=xePknD5eQgU i think about a Woodframe, to do an interpretation of the "Daimler Reitwagen" ...https://www.youtube.com/watch?v=SGiy0XcTPjk
Greetz Heri
sirpedrosa
Re: Lister help
« Reply #14 on: August 16, 2019, 09:29:02 AM »
Hi Onkelheri
Don't spoil your Lister D. This is a truly stationary engine. Put something of his age...
VP
