Author Topic: bryce pump on petter pj1 will not prime  (Read 6012 times)
rodc
« on: July 21, 2019, 12:32:41 PM »
hi
I have a fuel problem with which I am getting nowhere.
The original problem that the previous owner had was that the engine would start and then stop as if it had no fuel.
He unsuccessfully tinkered with the pump, so I decided to simply replace it for a fresh start and bought a replacement pump from stationaryengineparts.com.
The existing pump was a Bryce FA0AB080C0280 which was replaced by an FA0AB080C0770
Fitted the new pump, but the engine would not prime.
I bled the system as in the manual but the primer didn't really seem to be pushing fuel up the pipe although it was operating and I could see a change in fluid level at the top of the pump with the injector pipe disconnected but was expecting more of a burst rather than just a level change.
I took off the fuel pump housing cover plate to check the action of the tappet and primer and it seemed ok, although I'm new to these engines.
Regardless of how long I operate the primer no fuel comes out the pipe at the injector end.
Took the pipe off and blew it through with an airline.
Thought at first it was possibly drawing air in so spent an age sealing everything up around the fuel filter/pipes and bleed screws but to no avail.
I found yesterday afternoon that if I filled the tank so that the fuel level was above the injector, fuel simply flowed out of the pipe at the injector end in a continuous flow by gravity.
I don't think I did anything wrong when fitting the pump but I am stuck so there must be something
Any suggestions would be really appreciated.
thanks in advance
Rod
Re: bryce pump on petter pj1 will not prime
« Reply #1 on: July 21, 2019, 02:22:19 PM »
Hi Rod, I am not familiar with your engine but my fist question is does your engine have a fuel lift pump and filter that send diesel to the fuel injection pump? My second question is does your injector pump have a small hole/inspection hole about one inch up from it`s base?
My first question relates to non delivery of fuel to the injector pump, this could be due to filter/fuel blockage or a damaged fuel lift pump. These lift pumps have a rubber diaphragm that does not last forever, they are generally driven by a short tappet rod off one of the cam lobes, these can also wear causing inadequate compression of the diaphragm. I have seen situations where too thick a gasket between the engine and fuel delivery pump is enough to stop them working.
My second question relates to whether or not the fuel injector pump is being driven up and down by the camshaft below, you should be able to see it`s action through the inspection hole, if it is not going up and down you have a problem with your cam or cam follower.
Please come back with what you find,
rodc
« Reply #2 on: July 21, 2019, 06:17:50 PM »
hi
thanks for the response. The engine is the same as the PH1 as far as fuel is concerned.
I've attached a picture of the pump
It doesn't have a lift pump it is entirely gravity feed with the tank above the engine.
As part of my earlier struggle I replaced the fuel filter and all  the copper/fibre washers.
There is plenty of fuel getting as far as the injector pump which flows out of the bleed screw.
This afternoon I took off the pump case cover to expose the cam follower and primer.
I checked the primer and observed that it was pressing the cam follower up and down against the underside of the pump.
I then spun the engine and observed that the camshaft was causing the cam follower to also operate the pump.
So everything seems to be working apart from no pressure to the injector.
I'm starting to lean towards the very unlikely possibility of a faulty pump.
Rod
« Reply #3 on: July 22, 2019, 12:03:51 AM »
Hi Rodc, If you have fuel to the injector pump, it`s been bled and the pump is being operated by the cam tappet and primer but it still pumps no fuel there are only two possibilities. The first is that you have a faulty pump the second is that the pump rack is too far to the left and is in the fully off position. Try disconnecting the linkage and manually push the rack all the way to the right, maximum fuel position. Now try your priming procedure and see if it pumps fuel.
I have read reports of new pumps not working because they have been in storage for a very long time. The diesel they were originally  tested with evaporates leaving a very nasty thick varnish that is a bugger to get rid of. Stripping a pump is not that difficult but does require absolute cleanliness. Do you know if this pump is brand new or is it a reconditioned unit. If it is reconditioned it may have been reassembled incorrectly.
« Reply #4 on: July 22, 2019, 12:37:59 AM »
That fuel will flow through the pump to the injector line by gravity means you most definitely have pump issues. The delivery valve in the pump should stop that ftom happening and the varnish that Bob mentioned could very well be the cause or it could be missing parts or assembeled wrong.
rodc
« Reply #5 on: July 22, 2019, 10:18:45 AM »
many thanks both, it's really helpful to get your input.
The pump is a reconditioned one.
My original ignorance on these engines - although that's changing :-) - makes me reluctant to make judgements myself.
38ac's confirmation that the gravity flow is wrong is a great help.
Looking at the drawings I thought that should be so, but........
Having come down firmly on faulty pump, I sent a mail to the suppliers yesterday and hope to have an answer back today.
I think there must be a universal "Rods Box" for faulty stuff to go in that can be dipped into when I order things :-(
Many thanks again to you both, I'll report back once I hear from the suppliers
Rod
« Reply #6 on: July 22, 2019, 12:52:20 PM »
Hi Rod, welcome to the diesel learning curve,enjoy it and let us know what you find out.
« Reply #7 on: July 22, 2019, 04:08:28 PM »
I had a Rajkot IP that I had to strip down and thoroughly clean out before it would run, it came with an injector that was nearly as bad.
Still there was zero corrosion.......
rodc
« Reply #8 on: July 25, 2019, 06:27:50 PM »
hi folks
well, on the instructions of the supplier I opened up the pump, something I would never normally do on a new part, as he thought contamination might be keeping the valve open.
Inside I found two faulty parts which I would say would cause a bypass flow past the valve.
The attached photo doesn't show it very well, but  the bottom edge of the top union is damaged and burred over and the cork? washer has a cut across it and is split.
Just about to send the whole thing back. Really cross, I seem to have spent days on it in one way or another.
On this dumper it's not the quickest thing to change.
When I get a working pump, I'll hopefully report back success.
Or come back with another question :-)
thanks again
Rod
« Reply #9 on: July 26, 2019, 11:56:31 AM »
Hi Rod, I have dismantlement and rebuilt a few injector pumps over the years, I don`t remember ever seeing a fiber washer inside of any of them. Copper washers and ground mating surfaces yes, fiber washers no. If this is what passes as a reconditioned pump I dread to think what it must have been like before it was "reconditioned".
Give them hell,
rodc
« Reply #10 on: August 03, 2019, 10:39:02 AM »
hi folks
an update.
I've just received a replacement pump, although the chap I have been mailing with said they would replace the washer and set the pump up, they have sent an actual replacement, I'm glad to say.
Before I fit it, I'd appreciate bouncing some questions off your collective brains please.
The guy from the supplier maintained the following
1. When fitting the replacement pump the spill timing should checked and set by removing the top union and fitting a spill pipe etc
    If this is not done, the cam thrust could be too high possibly breaking the plunger spring in the pump.
2. The original problem could be contamination in the fuel keeping the delivery valve open.
3. The washer was most likely broken by my tightening the pipe nipple nut down too tight.
My responses were
1. As the pump is a direct replacement and the engine was previously running, I can't see why the timing should need to be changed unless, once the engine is running, there seems to a tuning need. I really cannot see a situation where the delivery spring could be damaged by the extent of the cam thrust when the pump was supposed to have been tested on a Hartridge fuel pump tester with a custom built cam box.
2. I found this hard to accept.
3. I could not believe in a possibility of me tightening a nipple nut so as to disturb the union that had been torqued up to 40lbf ft
So although I can't see any sense in it and still think that the pump was faulty on receipt, I'd appreciate others dispassionate views before I fit it.
thanks in advance
Rod
oldgoat
« Reply #11 on: August 03, 2019, 11:05:27 AM »
After your suppliers previous attempt checking the timing might be a wise precaution.
2 and 3 sound like excuses for a dud pump.
rodc
« Reply #12 on: August 03, 2019, 11:39:17 AM »
thanks,
>...checking the timing might be a wise precaution.
true. I'm just reluctant to disturb anything on the pump other than initially simply fitting it.
If the adjustment was out, could that damage the pump or would it simply be a running issue?
rodc
« Reply #13 on: August 15, 2019, 10:08:56 AM »
thanks to everyone who responded on this.
the pump has been replaced so I'll close this and raise a new question specifically about spill timing
hope  that's ok
Rod
