Start-o-Matic baseplate - thread type?
Matt J:
Hello Everybody
I bought an early '50s (I think) 6/1 a few months ago, which at some point used to be most of a S-O-M. All the generator bits are gone though now.
I've had it running but would quite like to make it do some work, probably some form of generator.
It is mounted on a cast iron base plate - there is a machined flat section and four holes where the alternator would have sat. Please could somebody tell me what thread size these holes are? They're not 1/2" BSW or 1/2"BSF.
Many thanks,
Matt
ajaffa1:
Hi Matt J, up until the 1950`s the Brits had a whole lot of different thread patterns and sizes, they then moved over to the Unified system. There were two types of threads: Unified Coarse and Unified Fine, generally speaking if the thread is into cast iron it would be UNC. This is almost indistinguishable from the earlier Whitworth thread system except that one has a 60 degree thread angle while the other is 55 degrees.
38ac:
They are very likely 1/2 UNC. Most of the Lister equipment of that vintage that I have been around was marked if manufactured with Unified threads. I don't believe that the CS engine was ever changed but that is only based upon what I have had my fingers in. The UNC and UNF thread patterns follow the SAE(coarse) and USS(fine) patterns of the United States with tolerances being the only difference. They are interchangeable other than critical applications. The 1/2 UNC at 13 TPI does differ from BSW at 12.
Thread gauges are cheap. Id bet that a 1/2 USS capscrew will thread right in.
Matt J:
Thanks all,
Having now spent a bizarre amount of money on four 1/2" BSW bolts (didn't fit), then four 1/2" BSF studs (didn't fit) I will treat myself to a UNC thread gauge and try that.
Will let you know...
Thanks,
Matt
Hugh Conway:
Just checked my 1954 start-o base.
The bolts and base threads are 1/2" 12 TPI.
Your mileage may vary
