Bits:
quite a bold jump you have made, i will endevour to answer some of your concerns.
first of all i never called anyone an idiot for using anything, i just question its use, and if that makes you or anyone else feel like an "idiot" then that is your problem.
if something is reported to work it should stand up to scrutiny, should it not?
how do you scrutinize? unless you ask questions!
the attachment of folks like the wright bros. galileao, divinci, and rudolf, to your arguement really has no bearing on the disussion and gives no validity to the
claim that desulfators either chemical of electrical work or don't work.
i have never said, that one should not use desulfators, what i did say was perhaps more common methods should be used first, then when all else fails use whatever you like. i also said that i would use a ground up dog biscuit if i thought it might work.
on the issue that no one told me to use it on my new batteries, you are right no one here did, but the EDTA folks recommend its use in new batteries! Funny how no one else does!
oh yes,, and lastly lets look at your apples to concrete block comparison of rudy and his diesel vs EDTA
Rudy built an engine, it could be observed to not only run, but do useful work,,,,,, by everyone! in every instance, any where, any time!
Unlike EDTA, which might do the job, sometimes, for some folks, with some batteries with some success.
NOW FOR THE FINALLY,, PLEASE READ THIS CAREFULLY!
if i brought home a huge battery that had been scrapped, and i couldnt get it to work using conventional means, I WOULD USE EDTA AND/OR A DESULFATOR, WHAT WOULD I HAVE TO LOSE,,,, nothing but my time.
if i messed up my high dollar batteries, i would follow recommended procedures to try and recover them, failing that, I WOULD USE EDTA AND/OR A DESULFATOR, WHAT WOULD I HAVE TO LOSE,,,, nothing but my time.
if however my high dollar batteries are functioning normally, as expected, no fucking way i am going to use EDTA or a desulfator on them , until
i see a report from a lab that backs up their claims.
would you add EDTA to a 4,000 dollar battery bank from the git go, as advertised by the suppliers of this stuff? or would you routinely use a desulfator on them? or would you follow what 100 years of science has taught us about these flooded cells?
if so you are either, 1. very rich and can afford to experiment on someone elses claims, 2. misinformed, 3. a gambler, or 4. convinced by solid research that they work, or
5. (failing all the previous reasons,) an idiot.
i hope i have made my position clear.
