further observations on the use of automotive alterators
one has to consider a couple of points
1. these units are built on a price point objective, in other words, how cheap can we make em and still get the job done
2. they are made to operate over an extreme rpm range, effectively being a jack of all trades, master of none.
you have to find the sweet spot, or in effect the most efficient rpm of an alternator to get the most out for the least input in hp and fuel.
if you want 50amps output, it makes no sence to spin it at 8000 rpm to do so, when in reality the thing might put out nearly as much at a much lower rpm
for instance a leeceneville 110-555 will output 90 amps at ~1500rpm, it has a top speed of ~8000 rpm, to get 90 amps at 8000 rpm will take substantially more hp than if you run it at 1500rpm
this is why it is important to check out the output curves of any alternator, if you cannot get output curves pass on that alternator, unless you have alot of money and time to experiment with belt/pulley ratio's
the next consideration is the prime mover/engine, most have sweet spots as well where, noise, vibration, fuel consumtion etc are at agreeable levels, what that rpm is needs to be known
once having both rpm of the alternator and engine the ratio is easy to figure, then you have a set that runs smooth, as quiet as possible, and as economically as you can. next..
another issue is the voltage regulator used for automotive applications, it is poorly suited for offgrid deep cycle work. most folks already know this, but some may not. if you don't know this you will be disappointed in the operation of your genset.
while an automotive regulator will charge your batteries it will take a long run time to do so, marine charge controllers and their counterparts take sophisticated control over the alternator and the charging regime of the batteries, to pump in the maximum amps based on temp, battery type, state of charge and other factors.
hope this helps someone, to save some time and money and make for a useful outcome.
