Author Topic: Excited soon-to-be caretaker.....  (Read 11343 times)
Re: Excited soon-to-be caretaker.....
« Reply #15 on: June 24, 2019, 07:12:14 AM »
Be very careful if you lift by crankshaft or flywheels, the engine is top heavy and can try to rotate.  Maybe not so much with a ST-generator on the frame.
« Reply #16 on: June 24, 2019, 10:37:16 AM »
Glad you got one safely, looking forward to seeing what you find when you strip it. When are you picking up the 12/2?
Do you have a manual for the ST head? I think I have one somewhere.
« Reply #17 on: June 24, 2019, 02:27:49 PM »
Looks like the unit is in good shape.
Congratulations.
CAVEAT:
Listeroids have soft crankshafts.
Do not lift by the flywheels.
Lifting straps should be looped around the bearing housings where the crankshaft exits the block.
People who say they lifted by the flywheels with no issues were just lucky.
Veggie
dkmc
« Reply #18 on: June 24, 2019, 02:33:39 PM »
Thanks guys!
There is a lift ring that screws onto one head stud. Is it OK to lift just the engine by that method?
I have a forklift that's easily capable of lifting the entire skid, but not so easy to get to it on the trailer right now.
Bob, no manual for the ST head, would love to have one.
The 12/2 trip is scheduled for this coming weekend.
veggie, Yes, it's new, never been run, no oil in the sump.
« Last Edit: June 24, 2019, 03:00:47 PM by dkmc »
« Reply #19 on: June 24, 2019, 03:19:28 PM »
I wouldn't lift the heavy steel base and generator with one head bolt myself, only the engine.
dkmc
« Reply #20 on: June 24, 2019, 04:03:18 PM »
Yes, that's what I was thinking.
« Reply #21 on: June 24, 2019, 06:12:18 PM »
Be careful when setting the engine down.  If it hits hard with the flywheels on, you CAN get some permanent distortion of the crankshaft, adding slightly to run-out.  It's a chore to straighten, so set her down gently.  I had this happen due to freight carrier, with engine on a pallet!
dkmc
« Reply #22 on: June 24, 2019, 06:34:28 PM »
Bruce,
You're reminding me of a small Sattley hit & miss engine who's crankshaft I straightened this spring for a friend.
That crank was soft as a tootsie roll.
You've also got me wanting to stick an indicator on the wheels now and check runout. There were some rough roads down in Pa.
On the way down empty we traveled Rt 81 and 84, they are just unbelievably rough with 6-8" deep pot holes in places. Lucky to have missed all of them, not sure how I made that happen. I came back on 6 an 171, 2 lane, slow speeds, a bit smoother traveling.
« Reply #23 on: June 24, 2019, 06:40:38 PM »
Checking runout is always a good idea, but potholes on rubber tires won't be a problem, it would take serious abuse; a hard hit. If you go to straighten the crank, you'll see that it's NOT that soft.
dkmc
« Reply #24 on: June 24, 2019, 06:45:21 PM »
Lots of good info and practice here, really appreciate the info!
« Reply #25 on: June 24, 2019, 11:47:40 PM »
I lift them by chokeing a. 1 1/2" strap around the head. Go behind the pushrods so they don't get bent and choke it between the intake and exhaust ports.  Pics later
2Ton46
« Reply #26 on: June 29, 2019, 03:21:40 AM »
It's always exciting to get one home! Do go through it, it's probably got enough sand inside to build a small castle - and not the kind you get to live in. In no time you'll be enjoying it. My twin is very popular even with people who don't even know what an engine is mainly due to the random stuff I have it powering. Everyone comments on how it chugs along but isn't interrupting their conversation like almost anything "modern" does.
dkmc
« Reply #27 on: June 30, 2019, 04:48:06 PM »
Well, the 7 hour trip to Maine to get the 12/2 Metro was a success.  What was looking like a sketchy adventure to line up a roll back truck to pick it up, then transfer to the rented flatbed, changed into a piece-of-cake when I went to pick up the rental and discovered it had a 3300lb lift gate. I had no idea they even offered them, and found it odd the salesman never suggested it when I told him the purpose of the trip. No matter.......it all worked out just fine.
« Reply #28 on: June 30, 2019, 04:52:27 PM »
Very nice steel base.  Congrats on the safe and successful trip!
dkmc
« Reply #29 on: June 30, 2019, 04:59:55 PM »
Thank you Bruce!
