Author Topic: lister JP3 filter mod  (Read 1872 times)
oldtime
« on: May 07, 2019, 11:43:11 PM »
Hi all I have seen a couple of fuel filter mods for the original Cast iron fuel filter .
 I want to know what fuel filter people are using . I can do the machining but cant find a suitable filter .
 My local filter place was a total waste of time . thanks to all
Re: lister JP3 filter mod
« Reply #1 on: May 08, 2019, 01:16:08 AM »
 I have zero experience with the JP engines but if the filter housing is similar to a CS I have a couple modifications that will work or you can with a RACOR in line unit and have superior filtering
sirpedrosa
« Reply #2 on: May 08, 2019, 01:57:15 AM »
« Last Edit: May 08, 2019, 09:44:09 AM by sirpedrosa »
By order of firing up:
oldtime
« Reply #3 on: May 08, 2019, 02:32:23 AM »
that's is what I want to do .. Any idea of the filter number . I can make all the bits just the filter number is what I need ..
sirpedrosa
« Reply #4 on: May 08, 2019, 08:34:11 AM »
Hi Oldtime
take a look at the same thread here: http://listerengine.com/smf/index.php?topic=8320.msg97812#msg97812
If you work with imperial mesures you rather follow Ac38 advice.
BR
« Last Edit: May 08, 2019, 08:36:17 AM by sirpedrosa »
