Author Topic: Lister sr1 Genny  (Read 5823 times)
Bolens
Lister sr1 Genny
« on: April 24, 2019, 11:50:25 AM »
Hi
Got one with a 220/110 output but only getting 12 v ?
Any ideas please
Thanks
Re: Lister sr1 Genny
« Reply #1 on: April 24, 2019, 01:22:19 PM »
Hi Bolens, you really need to give to give some of the clever dudes here a little more information. I am guessing that you have an alternator/generator built by Brush. These are interesting in that they built a generator, a dynamo and a starter motor all into the same unit.
My initial thought is that if it is only pumping out 12 volts, when it should be doing 110/240 volts, you have a wiring problem or are measuring the output from the battery charging circuit.
There are a great many possible issues please provide more information.
Bolens
« Reply #2 on: April 25, 2019, 02:30:02 AM »
Thanks
Will get plate later
Really struggling to get put on here at moment and appreciate how they help
Bolens
« Reply #3 on: May 01, 2019, 12:31:12 PM »
HI, struggling to post pictures on this ?
Any help appreciated.Thanks
sirpedrosa
« Reply #4 on: May 02, 2019, 12:31:53 AM »
Hi Bolens
Put pics in "atachments", under 1MB, ~920kb (shrink with MSOffice pic manager - or other - resize and crop)
Br
VP
By order of firing up:
Bolens
« Reply #5 on: May 02, 2019, 09:18:32 AM »
Thanks
sirpedrosa
« Reply #6 on: May 02, 2019, 03:17:40 PM »
Hi Bolens
I'm sorry what I wanted to say was ~ 920 pixels wide.
Br
VP
Bolens
« Reply #7 on: May 03, 2019, 06:17:15 AM »
HI, managed to post a pic !!
Bolens
« Reply #8 on: May 04, 2019, 05:17:21 AM »
Hi,posted some pictures any luck on why it wont give out 240 guys ?Appreciate any assistance as she is far too good to break up
oldgoat
« Reply #9 on: May 04, 2019, 01:27:03 PM »
I think the rear plate with all the brushgear can be rotated on that model You could try moving it a few degrees and see if there are any changes to output.
« Reply #10 on: May 04, 2019, 03:12:22 PM »
If you can find a schematic for that head I might be able to suggest troubleshooting via volt-ohm meter.  Checking continuity of output windings and field coil are one place to start.  Flashing (applying 12V) to the field coil on a long out of service unit is often required.  The regulation circuitry may have some failed components too, but I have no experience with this one.  Worth a trip to your local generator repair shop if you lack the skills, but finding the schematic may be essential for them as well.
Bolens
« Reply #11 on: May 05, 2019, 05:41:24 AM »
Hi,yep reckon a flash is where it is at but first will try to locate genny specs .Got a plate on I am sure but will look when it is light.Is there a library on here of gen specs ?
Bolens
« Reply #12 on: May 05, 2019, 05:43:13 AM »
Thanks oldgoat .What model is it if you know ?
Just trying to nail down circuit diagram as don't want to fry if I flash .Pretty good nick the actual wiring in there and brushes look  ok
Bolens
« Reply #13 on: May 05, 2019, 06:16:50 AM »
Here is plates
oldgoat
« Reply #14 on: May 05, 2019, 01:49:52 PM »
Ajaffa put up a circuit which I think applies to your generator in a post started by Onzlow on Nov 21-2018.
