Author Topic: stratomatic 6-1 oiling  (Read 196 times)
Lister Rob
« on: April 08, 2019, 08:33:23 PM »
 On the hub before the flywheel on both sides there a screw on top of the hub. Is this for oiling or just oiling on a rebuild. I change the oil regularly but was wondering if I have to add oil to this location and is there any other areas for oiling . I know you have to grease the cam and the bearings on the generator on both sides, Thanks.
Re: stratomatic 6-1 oiling
« Reply #1 on: April 08, 2019, 09:43:18 PM »
That screw locates the crank bushings. It keeps them from moving. No need to oil there. Probably not a bad idea if it has been sitting for a long time but you can accomplish the same thing by pumping the oil pump primer handle.
« Last Edit: April 08, 2019, 09:45:15 PM by broncodriver99 »
Lister Rob
« Reply #2 on: April 09, 2019, 03:02:31 AM »
thanks
