Author Topic: Unidentifed engine recommission  (Read 3278 times)
Sean
« on: April 04, 2019, 11:32:40 PM »
Hello,
I'm in the process of recommissioning a 3-cylinder air cooled Lister that came out of a boat (and will be going back into a different boat)
I'm struggling with a spring in the assembly among the fuel pumps - it's to the right of this photo. It doesn't seem to be actually doing anything. Can anyone tell me what it is for and how it should be installed. Is there something missing here?
Thanks,
Sean
scott p
Re: Unidentifed engine recommission
« Reply #1 on: April 05, 2019, 06:54:26 AM »
I always thought that spring was there to keep the linkages tight in other words linkage wear compensation.
scott p
« Reply #2 on: April 05, 2019, 05:06:22 PM »
OK I get it now. I saved your pic as a  JPEG. Your engine came out of a boat so I am assuming it is set for variable speed. That spring setup is to adjust your low idle but it is usually placed next to the last pump towards the flywheel but I suppose it would work where it is. If I can figure out how to send a picture of the adjustment instructions I will do so. Basically once all setup procedures are done you "according to the manual" you completely slack off the speeder spring start the engine and use the spring setup you are looking at to adjust the low idle.
Sean
« Reply #3 on: April 06, 2019, 12:13:39 AM »
Ah, that makes sense, it is set for variable speed and a low idle adjustment would make sense. If you can send a picture of the adjustment instructions that would be great!
« Reply #4 on: April 07, 2019, 09:42:31 AM »
It would help if we knew what engine you have. I am guessing at an ST or SR 3. I have attached a photo of the spring on my ST2, not sure if it will help much as you appear to have a slightly different set up.
scott p
« Reply #5 on: April 07, 2019, 08:11:16 PM »
here are the pics sean
Sean
« Reply #6 on: April 09, 2019, 07:50:13 AM »
Thanks for this - it’s an ST3 if it’s been identified correctly. I opened up my SR2 but it has a totally different setup so that didn’t help at all.
Sean
Sean
« Reply #7 on: April 09, 2019, 07:50:40 AM »
Thank you!
Sean
« Reply #8 on: April 09, 2019, 09:17:45 AM »
Hi Sean, do you have the full workshop manual for the ST2 series Lister engines? I have a copy but cannot post it due to size limitations on the LEF, I can scan parts of it and post as required.
