Author Topic: Running temperature?  (Read 3238 times)
Jordan
« on: March 27, 2019, 09:30:40 PM »
My 6/1 is cooled by thermo-syphon from the attached 44 gallon drum.
I can control water flow with the gate valve on the drum's bottom opening.
A thermometer was obtained reading up to 120 degrees Centigrade.
I intend to install it on the lower pipe that brings water to the engine.
Is there a recommendation for the optimum temperature to run the Lister?
Hugh Conway
Re: Running temperature?
« Reply #1 on: March 27, 2019, 10:19:17 PM »
When using a thermostat in the upper connection, most use a 195*F 'stat.
I would read temps from the upper connection, as the outlet temp is the one you want to monitor. The temperature in the top of a thermosyphon cooling can be much different from the temp at the bottom.
I used to use a tank/thermosiphon set up for my 6/1 but changed over to a radiator because of the expense of the large amount of anti-freeze required for a tank in my climate.  My usual run time is 2 hours at load  (2800W) to recharge off-grid batteries. When I used a 30 gallon thermosiphon tank, only the top of the tank got warmed up in 2 hours.
I now use an old cast iron rad from a house heating system. Total capacity of about 5 gallons, No fan. Gets up to nice hot temp fairly fast and has not overheated with 6 hours of run time.
Read the temperature at the top connection, that tells you the temp of coolant in the head.
Hugh
1963 BMW R-27 project
« Reply #2 on: March 27, 2019, 10:27:22 PM »
A barrel in freezing weather is a very expensive cooling system.  Without a thermostat, a barrel would be hard on the engine unless engine runs times are very long.
Hugh's solution is ideal, but I couldn't find any cast iron radiators in AZ.
The smallest, cheapest radiator you can find is more than adequate with either some cheap muffin fans or induced draft, which I use.  It will pay for itself in antifreeze savings.
« Reply #3 on: March 28, 2019, 07:33:11 AM »
Hi Jordan and everybody else, there is a thermostat conversion here: https://www.stationaryengineparts.com/Lister-CS-Thermostat-Kit.html
I believe this would work very well if coupled to a suitably sized radiator, perhaps something from a motorbike would be about the right size or something larger if you want to avoid using a cooling fan. The important thing to recognize is that Lister CS engines were never designed to run with a positive pressure in the cooling system. coolant will blow through the head gasket and end up in the sump or cylinder or both, causing problems. I am sure it is possible to design a set of gaskets to overcome this problem, but it would probably be prohibitively expensive. Much easier to go with a header tank open to atmosphere.  The problem with an open header tank is that over time the anti-freeze in the system will evaporate and require topping up.
I have for a while been wondering about the possibilities of oil cooling but have not had the time, money or energy to experiment with it.
« Reply #4 on: March 28, 2019, 10:06:56 AM »
Hi Glort, I`m not entirely sure if the antifreeze evaporates or if it is just the water. I do know that is very toxic and is loved by pets because it tastes sweet. If you are dumping it onto the floor please keep your dog away.
If I were to try for oil cooling, I would be looking at using a thin hydraulic oil or even an automatic transmission fluid.
Mercedes have always produced first class vehicles, I have been lucky enough to drive a few of them. Their diesel offerings are probably the best on earth. When it comes to comfort and heating you have to remember that they sell a lot of vehicles to Russia where winter temperatures can drop to minus fifty degrees centigrade. A heater needs to be exceptional to cope with those temperatures. I believe the quick warm up is achieved by the heater take off pipe being before the thermostat and radiator pipes.
I remember taking the old Mitsubishi Pajero up into the French Alps to go skiing. Despite it being diesel, it was the only vehicle that would start at minus 30 centigrade because it had twin batteries. Batteries at those sorts of temperatures freeze into a sort of Jelly that won`t crank out the amps needed to turn an engine over. Made myself a few quid and a lot of friends driving around providing jump starts to the locals.
I wasn`t suggesting Jordan should pay out for a new radiator, there has to be a breakers yard near to where he lives. A second hand bike radiator should be cheap enough provided it`s not from something exotic or rare.
Jordan
« Reply #5 on: March 28, 2019, 10:29:21 AM »
Lots of interesting replies to my query, thanks all.
I went with the big drum system because Lister seemed to have recommended it.
However I do see that over-cooling is a possible unwanted effect.
Anti-freeze I discovered was going to be expensive, but the engine is in a shed, though not an insulated one.
We get a few sub-zero Celsius days each Winter. Is it risky to not use anti-freeze in these circumstances?
I thought to avoid a thermostat to keep it simple. That has appeal.
I regret not using a radiator, I think. I do have one that could be appropriate.
It came from a very old big air compressor, so it cooled air. It has copper tubes with spiky, porcupine-like cooling fins on them.
I think it would do for the Lister, and looks interesting.
For the time being though, I will use the existing drum that I went to some trouble to install.
I'm thinking that temperature could be controlled by throttling the flow at the tank's gate valve.
Water at the bottom of the tank might be too cool, but restricted flow should bring the temperature to a happier level within the engine.
Temp gauge at the top to monitor.
Am I correct in this, or is there something wrong - maybe difficult to maintain a steady temperature?
At this stage I am always with the Lister when it's running, but in future it might be providing back up electric power and need to run unattended for lengthy periods.
« Reply #6 on: March 28, 2019, 12:50:31 PM »
Hi Jordan, in reply to your question about how important it is to have antifreeze in a Lister CS in a cold climate, it is absolutely vital! The cast iron cylinder block will freeze, the freezing water will expand into ice which will crack the cast iron casting and you will need to find a replacement cylinder block, or a very good welding engineer.
The cheapest solution in your situation would be to use brine rather than antifreeze but this also has drawbacks as is causes corrosion. What is your water supply like? If you have plenty, just watch the forecasts and drain the cylinder block if there is any chance of frost. Perhaps you could fit a few valves so you could drain the cylinder block without draining the entire cooling system/tank. The only other option is to try using a coolant that won`t freeze. I have considered using a radiator system filled with hydraulic oil or ATF, I haven`t tried this but there is no reason why it wouldn`t work. Perhaps you could be our crash test dummy on this and report back.   :)
Hugh Conway
« Reply #7 on: March 28, 2019, 05:06:53 PM »
A little more......
While the old cast iron radiator works great, I did go through a few to find one that had no cracks due to freezing before the present one came to me. They are hard to find now, though if willing to pay big money, they are available. I do use a 1 gallon expansion tank, it rarely needs topping up.
That's for my off-grid battery charging listeroid.
For the Dursley 6/1 that is used for my shop power, I do use a thermosiphon tank, albeit a small one. Would have used another cast iron radiator if i could have found one.  This particular tank is made from an old dairy milk can of about 15 gallons. The engine runs for short periods so heat build up is not excessive. That big cooling tank that Lister originally used was intended for 24/7 running.
Don't forget too that Lister did have  6/1 and 8/1 models that did have a radiator and belted fan, though it was a fairly large rad and the fan used power even when not required.
Many have successfully used a much smaller automobile or motorcycle radiator, unpressurized, with an expansion tank and electric fan. A good and relatively inexpensive solution that requires little anti-freeze.
Many options are available. we are fortunate to have forgiving powerplants and a variety of solutions at hand.
Hugh
« Reply #8 on: March 31, 2019, 06:35:34 AM »
I get freezing in my outdoor shed, and I run about a 20 gal tank, with 50% antifreeze.
It steams off water at the rate of about a gallon for every 15 hours of run time, and it's only the water that steams off, the antifreeze stays in the tank.
Everyone of us generating power, already has a cooling fan, in the alternator.  Just duct that past your tank or radiator, and as long as the belt spins the alternator, you have cooling
« Reply #9 on: March 31, 2019, 10:12:33 AM »
Hi Mike90045, I like your idea of redirecting the airflow from the generator head. Should be an easy modification using a bit of flexible ducting.
